What to replace when changing a engine
Some may have seen in my progress thread that my headgasket has gone so I'm replacing the engine with my 80k spare one
What do I change while its out?
Cambelt and tensioners
May do the water pump while its out
Oil and filters
Anything else I should do / change
I'm going to chop the air con pipes out while the engines out
Team Doesn't own a 306
I have replaced everything really. Gearbox seals, pinchbolts, cleaned all the steering rack, subframe, painted the bay up, new mounts and so on just because I cba doing it again in afew months but enginewise just belts as its a bitch to get to the aux belt when its in the car so I'd dred a cambelt
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
in fairness, oil maybe easier to change once the engine is in; if your engine isn't on a stand, draining oil and moving an engine is an absoloute pita once on the ground.
Do all you can afford
As above, EVERYTHING you can afford!
I could happily spend £500 on doing bits while the engine is out as theyer so easy to do while its out.
In no particular order things you should consider:
Full service; Oil, air and fuel filters and the oil itself.
Belts; cam belt, aux belt, all new tensioners and replace the water pump.
Seals; Inlet manifold gasket, exhaust manifold gasket, both crank seals, gearbox input and output seals, rocker cover gasket.
Full set of engine mounts.
All new coolant.
Set of decent glow plugs.
Brand new main earths and power cables.
Gear box oil.
PAS Fluid.
Water pipe O rings.
And actually the PITA water pipes so new matrix hoses and the one that runs alongside the engine.
I haven't got a unlimited budget so some things I won't change.
Ill change all the belts and good shout on the gearbox seals
How do you go about the crank seals?
Some good things to change there that I haven't even thought about!
Inlet, exhaust and cam cover gaskets are real cheap
Id change the cambelt, waterpump, clutch, gearbox oil seals atleast. its quite obvious that you need to change all the fluids aswell as hey need to all be drained when the old engine comes out
Inlet gasket will be changed when I put different turbo on and may as well change the rocker gasket
Any major things to change while the engines out that would be a pain to do while its in there
I changed my belts and tensioners, driveshaft seals.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
when i did my engine change i spent over £300 on parts!
complete list taken from my Project Thread
Engine
Cam Belt + Tensioner's
Water Pump
Manifold Gaskets
Down Pipe Gasket
Aux Pulley to non A/C one
Aux belt 1125mm
Leakoffs
Linkage (snapped when removing now gears feel lush!lol)
Oil + Filters
Power Steering Pipe + Fluid
Coolant
Radiator
Welding of Top Mount Cup
change all you can less headache in the future
Raccoon filter....
Question Leaky thermostat - which one to replace? akiller 6 4,827 30-11-2014, 11:55 AM
Last Post: akiller
  How to replace 306 1.9 TD DTurbo XUD9 DHY engine? shazilla 37 23,715 18-11-2014, 09:58 PM
Last Post: daniel.mountain.7
  306 1.9 TD DTurbo XUD9 engine replace questions ECU shazilla 33 27,486 09-09-2014, 08:35 PM
Last Post: shazilla
