DT starting issue
Thumbs Down
Right guys having issues with the DT AGAIN.
So the DT has been having issues starting again. Its really hit and miss. It does it when its cold but it will do it if its warm and its only been turned off 10mims before. It done this last year then stopped doing it all of a sudden its started doing it again (maybe the cold weather) but it isnt the starter and it isnt the battery and i wouldnt of thought it was glow plugs as it does it when its warm. Any ideas?
Tempermental solenoid? What does it do when it doesnt start? Just turn over and over and over and over? Any smoke at all?
Just keeps turming over. No smoke. But always starts with a bump
Swear that sounds like air leak. Im not sure though...
Pump the grenade and listen for hissing.
Agreed probably air getting in but if it's not even trying to fire then itcould be the solenoid, put a 12v feed to the top of it and you should hear it click
HDi Cabby Project Click
Very good point on the air leak that didnt even cross my mind Doh
With the solinoid is there anything i can do with it if it is at fault?
Not really just have to get another :p
Is it the one on the pump we are talkinf about here?
Yes Smile
Feck it ill just put my bosch on then
(01-12-2012, 04:52 PM)puglove Wrote: Feck it ill just put my bosch on then
Sounds like a better idea!
Time to count the pennies and get it on with a new belt me thinks
Sounds like an air leak to me. Also sounds like you've got the best solution to the problem!
[Image: 20120704_212316.jpg]
  Starting issue Chris_90 6 4,132 21-12-2016, 10:19 PM
Last Post: zx_volcane
  Slight starting issue, lumpy idle, etc Dazecoop 6 3,810 05-04-2016, 10:40 AM
Last Post: Iaitoo
  Starting issue again :@ sherman306 9 4,605 19-01-2014, 06:32 PM
Last Post: Tom
