Starting issue again :@
Right found a leak in the pump sorted that and starting wasn't bad for a few days now initial start is ok with a rev then it sounds like it misses loads and rev drop down to like 500 and feels shit once I drive it feels slow for a few seconds then pics up abit. Could this be fueling set too high causing these problems?
Nobody?
Keep it to one thread please mate, theres no need to have the same thread in 2 different sections, so i've removed the other one.
Are you running veg? Is your cold start cable connected?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Sorry mate just In need lol its mena be going tomoz lol guna drop the fuel in the morning and check for any loose connections and also would a loose injector union cause this?
Yes a loose injector union could cause that.
I've turned the fuel down and it does seem to be better now Smile
You got much smoke on full chat?
Lots and lots lol swapped it today for a bosched phase 1 lol
Probably a boost leak, shouldnt need to run that much fuel your having idle issues.
  Starting issue Chris_90 6 4,095 21-12-2016, 10:19 PM
Last Post: zx_volcane
  Slight starting issue, lumpy idle, etc Dazecoop 6 3,800 05-04-2016, 10:40 AM
Last Post: Iaitoo
  Non starting issue Garlicbread 22 9,919 17-11-2013, 07:49 PM
Last Post: Garlicbread
