Starting issue
I've got a strange issue that I've never come across before.
I do Alot of stop start driving car stays hot. When I come to start it it's like the battery is flat turns over really slow but if I wait 30 seconds for the glow plug relay to click off it'll fire straight away. I thought it was the battery so bought a brand new one but still same issue it's like the glow plugs are sucking all power.
I've done the same driving style on many xud's but never come across a problem like this before.
Car in question is a citroen bx.
check your earth points and that the terminals are clean on the starter motor
check starter isn't shorting / breaking down - worse when hot
(05-12-2016, 08:28 PM)bashbarnard Wrote: check your earth points and that the terminals are clean on the starter motor
I'll check them next time I'm under bonnet.
(05-12-2016, 08:45 PM)zx_volcane Wrote: check starter isn't shorting / breaking down - worse when hot
How would I check that it's shorting / braking down?
Have a good look at your main earth from the battery to gearbox/body.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Fitted a new starter motor other day and not had the problem again well not yet anyway.
result!
  Slight starting issue, lumpy idle, etc Dazecoop 6 3,802 05-04-2016, 10:40 AM
Last Post: Iaitoo
  Starting issue again :@ sherman306 9 4,587 19-01-2014, 06:32 PM
Last Post: Tom
  Non starting issue Garlicbread 22 9,952 17-11-2013, 07:49 PM
Last Post: Garlicbread
