Project Silver Fox
Project Silver Fox
Here is my project thread mirrored from "the other side". I think ill continue to update it on here though cause no one seems to give a shit.
Well got another dturbo as some may know a silver xrdt. Me and my misses have decided to call it silver fox. Got it from blackburn for 350 tax and tested. Has a few problems such as a pressurising cooling system front electric windows don't work and the central locking bounces back. Can't really complain for what I paid. Will create a check list and update this thread accordingly when I'm on the pc also will get some pictures on.
[Image: IMAG0014.jpg]
[Image: IMAG0013.jpg]
[Image: IMAG0012.jpg]
[Image: IMAG0011.jpg]
Things To Do (As of 1/02/2012):
  • Fix Front Electric Windows
    Fix Central Locking
    Good Clean
    Fit Lazers
    T-Cut some of the scratches out.
    Fit GTI 6 Beam
    Fit GTI 6 Fronts[/list:u]
    Completed So Far:
    • Fitted ICE
      Head Gasket
      Oil + Filter
      Fuel Filter
      Changed Alternator
      Running a KKK
      Cambelt Kit
      Water Pump
      Fit Bosch Pump
      Paint Calipers & Beam
      [/list:u]
      UPDATE:
      Engine is coming out on the 18th november. Head is coming off and going for a skim then a new head gasket set is going on. While its out a new water pump cambet kit, aux belt and alt are going on and is having a full service. Also bosch is going on while its out and having a good clean. Hopefully it will be back in by the sunday all running sweet. Will take some pics while were in the process.
      UPDATE: 19/11/2011
      Head came back today nice shiny and new. We managed to snap the bolt on the drivers side sub frame but we have made a new mounting bolt to hold it in place. Found out its running a KKK which is a shame but i dont really have any luck with the Phase 1's in the turbo department. Everythings all cleaned off and we have started to rebuild the engine. Just the inlet and turbo to go back on then we will lock it out and retime it and then the bosch injectors are going in and then it should be ready to put back in tomorrow afternoon.
      [Image: IMAG0196.jpg]
      [Image: IMAG0195.jpg]
      [Image: IMAG0194.jpg]
      [Image: IMAG0193.jpg]
      [Image: IMAG0192.jpg]
      [Image: IMAG0191.jpg]
      [Image: IMAG0190.jpg]
      [Image: IMAG0189.jpg]
      [Image: IMAG0188.jpg]
      [Image: IMAG0187.jpg]
      UPDATE 08/01/2012:
      Well its been eventful with this car, engine mount decided to destroy the mount point in the chassis but i here this is pretty common. So that has been welded up but has started knocking its cock off again (Back to the drawing board). May even buy one of those kits off the GTI 6 forums. Other than the engine mount everything seems fine, still bits and bobs to do which are mainly electronic such as the central locking and windows. Going to buy a pully, woodruff and a bolt from pug for the bosch pump and refit it why not at £37. Going to replace each side of the suspension and steering within the next week, both track rods drop links and wishbones. Hopefully i can grab some lazers aswell just waiting for a reply. Going to be getting a full GTI 6 brake set up including the rear beam and I am also thinking about getting an exhaust to stick on to free up some air flow! I imagine its probably time for it to be changed as it looks like its been on since 1996!
      Well thats all for now with my update if anyone can help or offer some advice please get in touch.
      UPDATE 21/01/2012:
      Well collected some more parts such as a full GTI6 brake set up, new front struts, track rod ends, drop links, a boost guage and discs and pads for the beam.
      Will be cracking on fitting some of this stuff tmorrow as now im going to FCS for the frist time i want it to be ready!
UPDATE 13/01/12:
Been and collected my parts from carious places. Went to Carlisle to see JDmotorsport.com for a all round GTi6 set-up including master cylinder. Then I went back down to preston to collect some lasers from C2K which where in near mint condition except for some light marks. Now the mission is to have it all fitted before the lakes meet!
Bosch pump going on tomorrow. Why have none of you miserable bastards commented Big Grin
Good thread pal be keeping a eye on this Smile
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
studturbo Wrote:Good thread pal be keeping a eye on this Smile
Cool another reppin a 5 Door!
nothing wrong with 5doors Smile
Mini update Bosch pump back on but one of the leak off barbs had snapped clean off the injector. Tried to weld it shut and use it as the last injector but it just wouldn't seal. One step forward two steps back. Running 3 Bosch and a Lucas injector
Am running 4 lucas injectors on my bosch pump a need some bosch ones Smile
Injectors sorted thanks to ed! Running rapid now. Turbo time methinks.
What's your future plans. Looks like a nice project!
[Image: Foxy2.jpg]
Foxy-jim Wrote:What's your future plans. Looks like a nice project!
Ill list some plans quick Big Grin
Get 4 tyres for my lazers
New radiator
Fit new track rod ends
Tracking
Then TD04 time i think Big Grin
Awesome! You lowering it or anything?
[Image: Foxy2.jpg]
Not to sure I might keep it sleeper
was a nice read :-) i like it. Td04 should be good
How about some stiffer springs and better shocks so it handles better?
[Image: Foxy2.jpg]
Got a lot of potential mate, silver P1 ftw!
Black 306 Rallye
Topaz Blue E39 530i Sport
Nordic Green 406 1.9TD
Foxy-jim Wrote:How about some stiffer springs and better shocks so it handles better?
I'll look into that any you can reccommend I may end up lowering it not sure
Bilstein b4s/b6s both very good Smile
I've never used any. How much to looking to spend?
[Image: Foxy2.jpg]
Bilstein b4 struts are £100 just FYI Smile
UPDATE: Just fitted two new track rod ends as it was knocking. Now its fine just needs tracking.
Nice project Smile
Tracking done just waiting to get some tyres so I can then fit all my Gti 6 gear.
Gti 6 Fronts are on including some new flexi hoses. Got some shit tyres on the lasers at the moment and rattle canned them black. Shit job but they will do for the time being.
FCS Weekend! Lets hope it dont fall apart on the way there. Note to self, new wishbones and ball joints when I get back. Also, weld the engine mount.
Got T1Rs all round great improvement also lowered 60mm ish on the front, back still standard.
Things To Do (As of 15/06/2012):
  • Good Clean
    Fit GTI 6 Beam
Completed So Far:
  • Fitted ICE
    Head Gasket
    Oil + Filter
    Fuel Filter
    Changed Alternator
    Running a KKK
    Cambelt Kit
    Water Pump
    Fit Bosch Pump
    Fix Central Locking
    Fit Lazers
    Fit GTI 6 Fronts
got any fresh pics dude?
  Project refresh - Silver Hdi Hatchback DavyCookie 18 10,995 03-09-2016, 06:52 PM
Last Post: MY95
  Project Silver Thing (PST) David 2 3,461 11-07-2012, 03:59 PM
Last Post: Pugmarshall
