rear strut brace
Was just wondering if my 1.6 99 plate (v reg) can have a rear strut brace because obviosly im on torsion bar so its not the conventional shocks so yeh any help would be much appreciated it
You can get thicker torsion bars and anti-roll bar to provide more stiffness for the rear
iv been thinkin about this. i was wondering if a A fame could be made? bolted over the front and rear beam mounts the welded to the archs in a simular way to the harness bar ?
Any one have any thoughts on this ?
Why???
As said the rear of a 306 doesn't have struts so You can't brace them
If you get the rear beam to twist then you have big issues!!!
Welding a frame between the rear beam mounts won't do much either
meeeh just a thought
There is a way to brace it a touch, not made one yet though, needs a little mod to the chassis to fit.
(15-11-2012, 07:29 PM)Rippthrough Wrote: little mod
Why does this sound like an understatement?
is this one of the "little mods" that require extensive use of an angle grinder and a welder??
Angle grinding and welding is a little mod. It's not my fault you lot get squeamish as soon as anyone comes near with a rivet gun.
(15-11-2012, 08:32 PM)Rippthrough Wrote: Angle grinding and welding is a little mod. It's not my fault you lot get squeamish as soon as anyone comes near with a rivet gun.
Never said I was squeamish lol, just that most wouldn't consder anything including an angle grinder a "little mod" Big Grin
Angle grinder, sledge hammer and welder are standard tools are they not?
[Image: signiture.jpg]
They're standard tools just for fixing a French car...
Well the point of the design is for them to flex and twist, so surely attaching some kind of brace would make bugger all difference?!?!
You've still got the spring and damper loadings to react into the chassis.
Would have thought with the load not being that great, it just seems a bit overkill.
Where abouts do you reckon would be best? I'm vaguely aware something can be done between the C pillars
just cage the whole thing, done.
(15-11-2012, 11:08 PM)samass Wrote: just cage the whole thing, done.
[Image: 35yn0a.jpg]
damn fuckin straight. Big Grin
Angel
That's your 'slight modification' to the shell, isn't it? A full roll cage!
If you want some sort of bracing then the A frame tie bar thing that he 206GTi180 has could fit and all the parts are about £300 from peugeot.
Supprised nobody has tried fitting one yet TBH
the gti180 what dum? :S
http://www.ebay.co.uk/itm/Peugeot-206-GT...416c983b0a
http://www.206info.co.uk/Forums/viewtopic/p=555263.html
^^^ That.
hhhhmmmm looks interesting. what would be the pros and conds on this?
Reduces the flex on the rear trailing arms but adds a bit more weight and friction in return.
Any noticeable improvement in handling?
Rear would be more predictable at the expense of a little ride quality.
  Vibration issues after strut brace installation S16 14 7,096 16-12-2014, 02:11 PM
Last Post: S16
  OMP strut brace adjustment nuts lolsteve 6 3,738 05-11-2014, 01:09 PM
  Strut Brace Help C.A.R. 8 5,421 30-03-2014, 08:32 PM
Last Post: Piggy
