De-glazing cylinders
I've just had a go at de-glazing my cylinder walls. I've watched quite a few YouTube vids first to try and get the right technique, and I think it went reasonably well.
What I didn't get from the vids though was how to know how much pressure to apply. I've de-glazed on the lowest pressure setting on the tool and its de-glazed and left score marks (although no where near as diagonal as before), but should I then tighten the tool and do it again?
Also the majority of the score marks are good, but there are a couple which are more obvious, and you can feel with your nail a little easier. Is this normal?
[Image: 20120704_212316.jpg]
What you using as a lubricant? last time i did this i used a huge tin of WD40 and medium rpm drill
[Image: J5hxCcC.jpg]
You want to use something like 3in1 for a lube. Fairly light pressure and keep at it on probably about 1/4 drill speed. You want the hatching to be slightly less than a 45 degree angle tk each other until the bores are almost a Matt finish. Don't be scared to put too much pressure on but just remember to keep it regularly lubed up....giggidy
Cheers guys, I've been using parrafin as that's what I was recommended.
(04-10-2012, 03:41 PM)Ben Wrote: Cheers guys, I've been using parrafin as that's what I was recommended.
Yeah thats also fine.....just isnt very nice to work with!
I used parafin, and made sure my movement in and out was fairly quick to ensure a half decent angle on the hatches.
(04-10-2012, 03:53 PM)Dave Wrote: I made sure my movement in and out was fairly quick
Giggitty!
^^ HAHAHA Go Dave!! LOL
  possible faulty injector, running on 3 cylinders rickye 11 6,461 13-02-2013, 10:09 PM
Last Post: rickye
