possible faulty injector, running on 3 cylinders
Having a problem atm, car was driving fine, running 100% untill about 3 hours ago, stopped it to talk to a mate in the town, when i went to start it again it turned over a couple times(odd as it usaly goes first go) and when it started it sounded like it was running on 3 cylinders, abit of white smoke out the exhaust, engine was shaking and down on power
so far ive cleaned the filter housing, wasnt any dirt in it and was full, so dont think the tank filter is blocked
took off the intercooler before i came in the house, started her, and slagged all 4 injector lines one at a time, when i crack injector 1 or 3, it changes its note, but keep running just about, when i crack injector 2 or 4, it stops
atm im thinking a faulty injector, as it was running 100% when i stopped it, then when i tried to start it, it started playing up
its on a lucas, only injectors i have are bosch, my 1st dturbo when i bought it had bosch injectors on a lucas pump, it ran but was dead, would it be ok to stick 4 bosch injectors in it to get it going, its getting my 11mm pump, timing belt etc next weekend, but i dont have the timing belt yet or id do that now
any help would be great, cheers Smile
edit, just had a quick flick through youtube there, could it be an injector stuck open
behaving about like this but only thats 6 cylinder, dturbo obv 4
http://www.youtube.com/watch?v=2Lh1IdMQfeQ
got it sorted now, she has either stuck a valve or bent it, 3rd cylinder no compression, so engines out getting a new one tomorrow
Could be the lines, I have cracked two no with intercooler pipes. See if there is diesel pissing out anywhere while its running.
naw, its not diesel related, changed injectors and lines made no difference, done a compression test after, 1,2 and 4 are grand, number 3 has nothing
shit luck man did you not just put that engine in?
[Image: 20gh7o0.jpg]
2 weeks ago, getting another one tomorrow so will have her back on the road tomorrow night, then ill rebuild this one
no luck atall lad
New engine new problems, 90% sure this is a blocked fuel filter but
Symtons
Hard to start, takes a gd bit of turning over to get going
Abit lumpy on idle, not running on 3 cylinders, just let's the odd splutter out of it
Spluttering like a lady garden when driving
And no power, boost is still there, but lost power
Sounds like a filter to me, just looking someone to confirm it before I burn the pos
try it! changing a filter takes less time than posting on here! lol
either that or timing perhaps...but get rid of the obvious first
Aye stuck in work atm, so gotta wait till I get home to change it, it slowly got worse on the way to work, so don't think its timing atm
Sounds like filter or possibly air getting in somewhere? As piggy said, try a filter first and you may aswell check the tank filter. Sucks to have had to change an engine 2 weeks after putting it in tho!
Ah ur not joking lad, worse when the engine you drop in starts playin about so quickly aswell
cheers everyone, bit of an update on this, as its now running like a sweety again, for another day anyway
after work she wouldnt start, at all, so phoned my da, and for the first time since ive been on the road, i had to be tow'd home, naw bad going considering its the 3rd dturbo
got it home, replaced a rather sucked in filter, and she fired, but was rough as hell, smoking like a steam train, dad thought rings n i said timing, drove her into the shed, sure enough, aux belt in half, top cambelt covers off and found most of it, some was around the bottom water hose, and some the window washer hose
locked the timing, didnt count it but was either 2 or 3 teeth out, so got away very very lucky
she running no aux belt for tomorrow, so gonna be a quiet sail to and from work, and home to fit a new belt
Cheers again for all the help
  faulty temp sensor? Ricky 11 7,217 08-03-2013, 11:00 PM
Last Post: Ricky
  De-glazing cylinders Ben 7 4,733 05-10-2012, 07:55 AM
Last Post: CJ_Derv
  not actually running a little hot (faulty temp sender) zx_volcane 12 7,024 29-08-2012, 08:36 PM
Last Post: zx_volcane
