03-08-2012, 09:47 PM
Everytime I brake there is a slight juddering through the steering wheel, had a quick look and the discs seem fine and not warped, anyone have any idea?
juddering under braking
03-08-2012, 09:53 PM
Can't tell if discs are warped by looking at them, and that's usually what it is, but if it's not that...
- Worn wishbone bushes/balljoints/TREs - Flat spots or deformed tyres - buckled wheels - loose steering column/rack - driveshafts/CV joints Could be any of the above really...
03-08-2012, 09:56 PM
If it's only under braking its more than likely warped discs. Could also be build-up on the discs though, which will disappear in time with use.
mine are fairly warped I think, it's a pain in the arse but not dangerous..
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING!
04-08-2012, 09:43 AM
Mine does the same thing, only under hardish breaking tho, if I break normaly or slam the f*ckers on then it's fine
04-08-2012, 09:55 AM
Looks like I've got some more checking to do then, would it fail its mot or does it just depend which problem is causing it, ed, that's a very good excuse to drive/brake fast
04-08-2012, 10:17 AM
Shouldn't fail an mot unless the car has significantly different braking efficiency between the two front wheels.
04-08-2012, 10:43 AM
ah thats okay then, need to get a few bits done before the mot in october, as long as it doesnt fail then ill leave it for now
04-08-2012, 03:48 PM
it will fail mot with a "fluctuating brake effort"-----------a buckled disc.
do you know how to use a dti guage? or have a mate who can get one???-then check the discs while the wheels are off to confirm that the discs are in fact made of soft cheese, and thats why they are warped.
04-08-2012, 05:04 PM
I have a little test for warped disks, feel free to laugh. Clamp a spanner or a screwdriver to the strut so it's almost touching the disk, then turn the disk and watch the gap between the 2. If there's any real movement the disk is f*cked...
| Braking on and off | MY95 | 20 | 9,932 |
19-03-2015, 10:20 PM Last Post: MY95 |
| what braking system | Willo | 3 | 3,278 |
23-02-2013, 01:21 PM Last Post: Willo |
| Bang when braking | kentiiboii | 8 | 5,220 |
09-06-2012, 06:46 PM Last Post: kentiiboii |
