ball joints which is better 16mm or 18mm
Just curiosity really as not sure to change my hubs to the larger size
Opinions plz
18mm was on the GTi-6s so that instantly makes it better by a magnitude of 6.
Hopefully someone will come along shortly with a real answer
as far as i thought, it made no odds?
only advantage i can see is the 18mm ones will be stronger, so therefore 'better', but if you're ever in the situation where you'd have benifitted from a stronger ball joint, id reckon that the rest of the car would be shagged anyway...
i have both on mine, cuz im thats how i roll.
(13-07-2012, 09:19 PM)samass Wrote: if you're ever in the situation where you'd have benifitted from a stronger ball joint, id reckon that the rest of the car would be shagged anyway...
lmao
jus sayin....
Pug upgraded them on the 6 from 16mm to 18mm why i have no idea. Confused probly not worth the hastle of swaping them over for a extra 2mm
(13-07-2012, 09:24 PM)R45_ODV Wrote: Pug upgraded them on the 6 from 16mm to 18mm why i have no idea. Confused probly not worth the hastle of swaping them over for a extra 2mm
but
but
girth!
Samass does ur car handle better on one side lmao
It's all about the girth!
Bigger balls FTW
(13-07-2012, 09:34 PM)R45_ODV Wrote: Samass does ur car handle better on one side lmao
actually....yes!
but thats down to other, tread related factors...
(13-07-2012, 09:52 PM)Curt Wrote: Bigger balls FTW
I think this needs to be sigged!
16mm = lighter!
Anyway, the 18mm's give a bit more strength for the lard arsed later models, and wear a bit slower.
GTi6s in Ph2 guise seem to have both 16 and 18mm though...
(25-07-2012, 09:45 PM)Ruan Wrote: GTi6s in Ph2 guise seem to have both 16 and 18mm though...
Standard issue, Peugeot consistency
Team Orange Engine Bay
Yep. Later on they changed over to 18mm but most ph2's have 16mm. Usually the 2.5's that went over to 18mm.
Ph2 has 16mm
ph2.5 has 18mm
I can not see any benifit what so ever in swapin from 16 to 18. Iv had both on my 6's . Currently on 16mm and i see no difference.
Thought this thread may help clear up any confusion: http://306oc.co.uk/forum/thread-2589.html
lmao
HDi Cabby Project Click
Rofl
Which is better?
Only one way to find out......................................Fiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiight!! Tongue
Yes, I'm bored.
I also have both lol
I have had a phase 2 with both as standard so just whatever they had in the skip at the time really
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(30-07-2012, 04:07 PM)HDIkyle Wrote: I also have both lol
Another, case of peugeot of their parts bin
http://www.googlefight.com/index.php?lan...word2=18mm
And there's the answer.
Lmao ruan lol, good way to decide
Flol Ruan!
  dummy cv joints pug306driver 10 5,292 28-09-2016, 05:49 PM
Last Post: pug306driver
  Balljoint 18mm or 16mm tim 306td 7 4,193 23-08-2016, 06:34 AM
Last Post: cully
  Ball Joints? JTaylor2005 26 12,032 28-04-2016, 09:36 AM
Last Post: toseland
