Rattle?
Been driving car today and pulled up at a round about with a old xud behind me and heared a faint rattle so thought it was the xud. Went down my local bypass got to ikebana turned the car off and the rattle was back but louder. So I had a look round took engine cover off as I know it's loose but it wasn't that been checking nothing's loose. Cam
Belt and aux belt was done 10k ago as well all tensioners and things.
Just had it remapped to stage 1 but I doubt that would cause a rattle.
I started the car when I got it home and it was quiet again. So turn it off tried again and it was loud.
Any one had anything similar? Or any ideas. Going to strip aux belt tomorrow see if it still accurs. If still there stripping cam belt cover. Just don't want to remove cam belt as I'm skint this week :/.
Thanks ladies and gents
Exhaust manifold bolts tight?
Hmm not sure will check in morning.
Well worth inspecting that end of the engine.
I did similar back in the day on my GTi6 as it rattled a lot and I was worried. Removed the aux belt, started it up and it was silent. So I put it down to a worn roller/tensioner on the aux belt area.
Not sure why it'd come and go so much though, usually they come/go when hot/cold.
Did you do the cambelt etc, or someone else? Was it a Dayco kit? Well worth having a check if it's still a bit noisy/rattly after aux belt off test... just visual inspect nothing has gone wrong.
I'm sure it'll be fine though, Peugeots rattle, if it's not the injectors it's the lower pulley or some other common rattly part Big Grin
Dave
I did the cambelt mate. Positive it was conitec I think the make it something on lines of that.
I took aux belt off other day and the noise had gone. When cara running noticed the pas pump was getting hot quick so we put it down to bearing in that. So we got a second hand one and fitted it today and it's still there no difference.
When we took the aux off the car was still jacked up so maybe it could be something in the engine.
Tomorrow going to try again taking aux belt of dropping car of jack and see if the noise still there. Of its still there I'll strip cam belt cover off and see what's inside there. If still nothing I fear it's something in my engine.
Dave not pointing fingers or anything. But do you think it could be something down to my map by any chance? Do you think it may be worth while uploading my old map and see if it makes a difference?
Any ideas everyone will be a massive help
Downpipe?
306 HDI, soon to be XUD
It's not that sort of rattle mate. It's more of a tappy motion sort of rattle. Higher the revs and it gets louder.
Can't think of anything at all in a map that could cause a rattle, beyond slightly increased injection noise. Rattles are caused by mechanical issues, my money would be on crank-pulley, tensioner/idler pulleys or maybe something knackered in your head. As in cylinder head, as opposed to "you're losing it mate" lol. Not heard of that belt company before, don't dismiss it just because it's been done recently. Did you do the work yourself?
Yeah my dad did the work don't trust my self yet with cam belt :p and I'll double check the make it was from motor factors anyway. I'm checking all cam belt today when my dad gets here. Hopefully it's not anything in engine don't wanna loose this car too attached
Continental is the cam belt. I just saw conti on sticker and made rest up. Smile
Now putting this down to crankshaft pulley. Took aux belt off again and it's gone had a good look round there's brown dust around the pulley. Plus all the nuts holding the cam cover had come loose around that area. So tomorrow picking up a pulley.
Got a rattle? Sure its not tappy?
/Ed Doe
Sorry about the lack of help lol
(15-07-2012, 06:55 PM)4WayDiablo Wrote: Got a rattle? Sure its not tappy?
/Ed Doe
No worries.
We're use to it Big Grin
Hahahah true dat!
I don't suppose the rattle has stopped now you've tightened your cam cover bolts...? lol Crankshaft pulley does sound like it's on it's way out from the description, hope that solves it for you.
Nope we thought it may stop when tightened them up.
Yeah got to search for a pulley today get some prices. But tbh looking at it I'm 90% it's the pulley. When I took aux belt off looking at it i could see it moving a little but wasn't sure if it was cos the engine moves anyway so I had a little tug at it and it does have play.
Conti belt should be fine, decent enough company.
This is the pulley people have been using as an upgrade, do a search on the part number and some bargains come up. Wink
http://www.ebay.co.uk/itm/GENUINE-FEBI-C...1c288be31a
This ones a little cheaper, same one as Poodle's link and with free postage mate........
http://www.ebay.co.uk/itm/271003297997?s...1852wt_892
Thanks you guys. Just one question. What's different about this one? What makes everyone go for it or is it just because it's cheaper?
Doesn't fall apart the same way the standard items do afaik. And because it's cheaper.
That's not a cheap one, this was cheap one (that's not a knife):
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...0741294501
lol
  Jingle Jangle rattle noise? tigerstyle 9 6,025 06-06-2016, 09:07 AM
Last Post: Toms306
  Rattle on lift off? JTaylor2005 9 5,214 01-06-2016, 02:46 PM
Last Post: JTaylor2005
  The real cause of injector rattle? JTaylor2005 136 86,413 27-05-2016, 07:37 PM
Last Post: Paul_13
