Jingle Jangle rattle noise?
My estate has developed a rattle over bumps/potholes etc. But it's not a rattle really it sounds like  jingle bells are stuck under the car?
Almost like the sound a completely loose jubilee clip would make rattling on an exhaust pipe - but  I've check them all and nothing seems loose?
Any ideas or obvious things to check, it's a very light musical still jingle...
Sounds quite pleasant tbh... lol
Loose exhaust baffle or heatshield I would guess.
Do we have heatshields?
I can't recall...
I only have a midbox, does that have baffles in it?
Yeah there's a metal heat shield in the middle, and a material one at the back.
I think there are baffles in the midbox yeah, not many but I don't think it's just straight through.
The other thing to cause that sort of noise is a knackered bearing with loose balls, top suspension mount bearing or wheel bearing etc.
Made me think of the Top Gear episode where they tied a cowbell to May's motor. Wink
I assume you've checked for rogue cowbells? lol
(05-06-2016, 01:33 PM)WiNgNuTz Wrote: Made me think of the Top Gear episode where they tied a cowbell to May's motor. Wink
It is so close to that sound, I checked underneath no bells found!
Didn't get a chance for a proper look underneath yet though.
Our estate made a noise usually on start up and when shutting down. I checked for a broken exhaust but did not find/see the crack in the front pipe taper joint with the middle section until I crawled under the car. The crack was seen when i jiggled the pipe and saw the crack open up.
Yours sounds like an exhaust related noise, but noises can be troublesome to identify some times.
something broken and tapping the beam tube??
Mid-box is a straight-through design. Check stuff like metal vac pipes etc are clipped in properly and not close to anything else. Only times i've seen this before it's always been something inside the car, insecure wheel braces and jacks are a favourite.
it maybe the r clip holding the drive shaft nut
(06-06-2016, 08:57 AM)madmadmax Wrote: it maybe the r clip holding the drive shaft nut
How did I forget that! Yes, that's another common one on 306s and is jingly. Hammer usually solves it lol.
  Rattle on lift off? JTaylor2005 9 5,394 01-06-2016, 02:46 PM
Last Post: JTaylor2005
  The real cause of injector rattle? JTaylor2005 136 89,195 27-05-2016, 07:37 PM
Last Post: Paul_13
  Injector rattle, boost pressure, and lift off rattle? JTaylor2005 10 7,654 30-03-2016, 04:33 PM
