Rear dampers too short?
Hi guys, just fitting two bilstein dampers (306 gti fitment) to a rear axle (new IM axle set up for zx volcane) and the dampers seem to be about 10mm too short.  Maybe my fault, as I took a punt on 306/zx parts being interchangeable, or is there something I'm likely to be doing wrong?  I'm certain that if i compress the axle this will then allow the dampers to be fitted, but then it would be the dampers holding the axle's spring tension, stopping it from fully relaxing, and possibly damaging the damper.  What do you guys think? Is there a difference in the rear beam setups between the two cars, or is it possible that the axle is set too high?
move the arm up, that's normal.
Thanks given by: dt_
Cool, that's a relief, those dampers were quite a bargain.  So I can compress the axle, fit the dampers and have the dampers support the axle, or do I need to remove the TBs and adjust the arms?
Just need to compress the axle so it makes the gap where the bolts go for the shocks shorter. No need to remove anything.
Ok guys, that's good to hear. Thanks a lot for your help!
  Putting dampers back on the rear beam Iaitoo 2 1,084 10-05-2016, 12:51 PM
Last Post: RetroPug
  Best Short Shift Kit (HDI) MY95 10 1,782 05-01-2016, 05:44 PM
Last Post: Magenta Sunset
  xud / hdi short shift kee616 2 1,241 11-05-2015, 08:35 AM
Last Post: kee616
