Best Short Shift Kit (HDI)
Would like a shorter throw, sometimes gets a bit annoying round town etc, what are these like? Doesnt sound like it will shorten it that much - http://www.ebay.co.uk/itm/261352895628
Any better options? Is it defo worth doing?
Cheers
I know of two cars that have these round me, both suffered from them moving occasionally on heavy changes, was sorted up changing the grub screw type and dimpling the shaft slightly with an angle drill once they'd found a position they where happy with.
I had similar on my AX for ages and it was fine .... until it snapped the ball off. I replaced it with a compbrake type (also available for the 306) that replaces the pivot assembly under the gear knob and found that to much better, theyre adjustable too
Hated the compbrake one. Worst modification I've ever bought.
Better off just changing to rose joints and making sure the engine mounts are good
P1 XSi track car
2.4 LWB T4
I have the pug1off setup on mine and haven't had a problem in the three years of use ever.
good price to.
Thanks guys!
Will that pug1off one I linked make a significant improvement?
Guessing you have a different one Impotentials?
I'd do as adam said, metal jointed linkages or rose joints and fresh bushes on the subframe, the throw isnt bad on a standard system with that fixed, make it too short and you can beat the synchros and wear them out.
or a satchshift.
Thanks for clearing that up Welshpug, just a bit too long for my preference from 1st to 2nd, which can get a bit tiring and annoying around town! Engine mounts all fine.
(05-01-2016, 10:45 AM)welshpug Wrote: I'd do as adam said, metal jointed linkages or rose joints and fresh bushes on the subframe, the throw isnt bad on a standard system with that fixed, make it too short and you can beat the synchros and wear them out.
or a satchshift.
where's a good place to buy such parts Welsh?
Hate Housework!
pugracing or bbm for linkages, quadrant bushes are pug.
will they fit a DW10 with a 'right & down' reverse?
Hate Housework!
  Rear dampers too short? dt_ 4 3,218 12-03-2018, 10:17 AM
Last Post: dt_
  quick shift Esmyth124 11 5,524 04-04-2017, 09:47 AM
Last Post: Mattcheese31
  xud / hdi short shift kee616 2 2,682 11-05-2015, 08:35 AM
Last Post: kee616
