Threads: 61
11
Car Model/Spec: rallye,Astor 6
Ok well day 1 was so mad with bits not fitting, not right parts in oil cooler was a right piss about.so we staeted with the oil cooler decided to go with a 16 row cooler as I have heard 13's aren't up to it.
So got the kit unpacked pipes where miles to long can't cut them because of the stupid ends so had to get the cable tires out
It was also a bloody good job I didn't have a gti6 twin fan setup or we would of been completely f*cked.we out out the second fan suround and mount it they.also replace the oil filter at the same time.
Sitting just to the side of the number plate
Engine looking very sorry for itself, no battery either
So we relocated the battery behind passengers seat
Rocker covers on and fc coil pack also sanded back cylinder head and autosoled it
Astor 6 Fast road/track project
Threads: 27
20
Given 0 thank(s) in 0 post(s)
Looks good chap! With regards to moving the battery did you just extend from or did you do all the live and earth points in the bay?
Threads: 61
11
(25-05-2013, 02:06 PM)Jonny b Wrote: Looks good chap! With regards to moving the battery did you just extend from or did you do all the live and earth points in the bay?
Cheers johhy I got some earths with the swampy kit I link on to a bolt on the battery box plate and we ran one (not the earth) into the fuse box.i can get pictures for you if you want my main problem was we had was we had no terminals at my mate garage so had to burn one of a old cable.
Threads: 61
11
25-05-2013, 05:18 PM
(This post was last modified: 25-05-2013, 05:32 PM by 7057sam.)
Threads: 476
81
Car Model/Spec: 306 Rallye
yesss! Brilliant stuff! Cant wait to have a ride in this at pugfest. Cant wait to see it tomorrow too!
Threads: 61
11
(25-05-2013, 08:35 PM)SRowell Wrote: yesss! Brilliant stuff! Cant wait to have a ride in this at pugfest. Cant wait to see it tomorrow too!
Yeah see you tomorrow mate, you should hear me first though
Threads: 51
4
Car Model/Spec: Did Have Track Prepared GTi 6
You've got the kid in a candy shop syndrome! Lol.
Much more left to get?
Threads: 27
20
(25-05-2013, 04:24 PM)7057sam Wrote: (25-05-2013, 02:06 PM)Jonny b Wrote: Looks good chap! With regards to moving the battery did you just extend from or did you do all the live and earth points in the bay?
Couple of pics would be good chap!
Threads: 61
11
(26-05-2013, 07:50 AM)Tallguy_2 Wrote: You've got the kid in a candy shop syndrome! Lol.
Not to much now was going to get a jetex cat back this week but got to do the bloody cam belt instead
Aero catches do on then and maybe lower the front abit see how the rear settle's over the comming days
Threads: 61
11
26-05-2013, 08:47 PM
(This post was last modified: 26-05-2013, 08:47 PM by 7057sam.)
Dropped the old buckets off a mr rowell today and had a little go on NFS underground 2, god thatvgame brings back some good memories
Got this picture this morning I got 50 like already on Facebook so thought it was worth showing
Threads: 61
11
31-05-2013, 08:27 PM
(This post was last modified: 31-05-2013, 08:29 PM by 7057sam.)
So started today painting up bits in the engine bay.
I used a vht paint, stupidly I did have the job then relised I was useing matt black instead of gloss but thought I do it then see if it grounds on me .
At work we have a seam cleaner so may give that a shot aswell
Before I started .
So did throttle body, cylinder head pas pump engine mount.
Shame with matt goes nt really do it justice but its alot better, think I ll do the cylinder head front bit as the polishing ant going as planned
Then I started on my spare wheel holder as I removed the original one
Haven't bolted anything in place yet though its a £3 replacement metal tabel leg from homebase and with a foam insert to stop the movement its great also got a strap the tire it down for good measure.
Still to do is painting slam panel and clean all the crap of the abs unit or blank it off with a plastic cover
Threads: 77
15
Car Model/Spec: oem+ phase 3 astor 6
This has soooo much win dude glad to see it on a black rallye to
Threads: 476
81
Awesome! Cant wait to get started on my car now!
Threads: 61
11
31-05-2013, 11:19 PM
(This post was last modified: 31-05-2013, 11:21 PM by 7057sam.)
(31-05-2013, 10:52 PM)SRowell Wrote: Awesome! Cant wait to get started on my car now!
What one
(31-05-2013, 10:19 PM)sam Wrote: This has soooo much win dude glad to see it on a black rallye to
Cheers mate I booked a track day at Snetterton next monday and my track time for fcs today so actaully using it for what I built it for
Threads: 150
14
Car Model/Spec: 306 HDI
Sam how much was fitting for the cage?
306 HDI, soon to be XUD
Threads: 61
11
(01-06-2013, 01:01 AM)declantg Wrote: Sam how much was fitting for the cage?
Me and carl did it he welded in the 'x' for £150
Was nt to hard to do apart from the the arch with the pertol pipe in is abit fiddly
May paint it again not shure yet.
Threads: 61
11
Adding some padding today, ordered it as RED but looks kinda pink.
Door card fail
So need to do some modding friday
New wheel spacer, tested greifly after and I'm in love think I can add 10mph to each bend
Before
After
Quick releases pretty quick aswell
Threads: 141
35
Car Model/Spec: 106 rallye, GTi6, Hdi dturbo
I bet its a right effort to use your indicators or wipers lol
Threads: 61
11
Yeah it's but weird, I had a dish wheel previously so was nt to bad.abit of a mission if your holding onto the wheel at the same time.
I got to do cambelt and aero catches tomorrow then doing a trackday will sam monday
Threads: 27
20
I got that padding in mine!! Give it a couple of weeks and it'll be proper pink bud ha ha!! Looking good though fella!! What track you doing?
Threads: 61
11
06-06-2013, 11:55 AM
(This post was last modified: 06-06-2013, 11:56 AM by 7057sam.)
Doing Snetterton on Monday the 300 circuit.Be great to finally put it through is paces and try not to brake it before pugfest/FCS.
Threads: 61
11
09-06-2013, 06:42 PM
(This post was last modified: 09-06-2013, 06:49 PM by 7057sam.)
Threads: 591
54
looking super sweet....shame I guna miss FCS.
Threads: 61
11
(09-06-2013, 07:03 PM)Piggy Wrote: looking super sweet....shame I guna miss FCS.
Cheers mate I'll be a pugfest aswell
My next purchase will be quite expensive so no more shinies for a while
Threads: 591
54
I'm away at pugfest, was at prescott hill the other weekend though, great place.
At CC, is it REALLY a true open pit for two hours??
Threads: 61
11
From what they making out yes as im on 10:15-12-15 I could be in the first session but they will be the 'off' here and they which will probably cut the session short.I have pugfest 2 weeks before which is always epic so aslong as I don't bin the car a combe its a win
Threads: 476
81
see you tomorrow for epic fun at snetterton!
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
Cars looking amazing! Are you doing snetterton tomorrow evening? I'm coming along to watch Dan in the RX8. Wouldn't mind asking you a few things about your car if I get a chance, I'm hopefully getting a track rallye/gti in the next few weeks.
Threads: 61
11
(09-06-2013, 08:55 PM)Ben Wrote: Cars looking amazing! Are you doing snetterton tomorrow evening? I'm coming along to watch Dan in the RX8. Wouldn't mind asking you a few things about your car if I get a chance, I'm hopefully getting a track rallye/gti in the next few weeks.
Yeah no problems,be great to see more of you guys from here. hopefully have a trouble free outing, have never driven Snetterton before either so will be a great learning curve and to see how far I can push it
Threads: 141
35
you really need a phase 3 boot, the strip looks so out of place on a smooth lid
