Threads: 1
Car Model/Spec: 306 20hdi
Country:
just changed fuel filter housing due to leak, now engine runs then cuts out and fault code 0230 fuel pressure circuit. everything was fine before, have tried to eliminate everything i have done apart from leaking bit now stumped
Threads: 49
What was it? I was thinking there may be a cap on the inner pressure relief valve.
Threads: 42
28
probably just full of air.
Threads: 1
Country:
have cured the cutting out but still getting the 0230 fault code and dropping into limp mode, did try a fuel cleaner which helped all points to high pressure fuel regulator on back of high pressure pump which seems to be a common fault and cause this issue, the only other possibility is i let the tank run very low just before Christmas and this may have dragged some crap pout of the tank, thus disturbing filter has allowed dirt into pressure switch. so will clean switch and see what happens
Threads: 110
20
Best bet is to plug peugeot planet into it as that should tell you what the issue is rather than getting you a generic fault code. Im in hemyock if you did want to pop over and i can plug it in as i see your only in taunton?
Threads: 145
I have pp2000 so if any member local to me ( Caernarfon ) needs it plugged in, just ask, glad to help, gratis for members.
