Oil Temp Gauge Help
Soo Im looking at fitting an oil temp gauge to my HDI i know ill have to modify the sump plug to monitor the temp but does anyone have a guide am looking at either pillar mounting the Gauge or relocating the cig lighter and having it there.
Any help will be valued.
Regards
Check Out My Build Threads // Puglet Build
might be a bung on the front of the sump as larger hdi engined vehicles had oil temp.
as for the gauge you could use the one from a gti6.
(03-11-2017, 09:57 AM)welshpug Wrote: might be a bung on the front of the sump as larger hdi engined vehicles had oil temp.
Dont mind sorting the pillar out as in the end am gonna run a few gauges sooo if i get a 3 pillar gauge holder it will be fine and ill try and find something would you have a clue in the direction of wiring it as wouldn't want to to melt the wire or catch.
Sad Help with temp gauge Nathan1305 2 3,333 21-08-2014, 09:23 AM
Last Post: Nathan1305
  Fuel gauge/Temp sensor pugtk 0 1,919 05-07-2014, 08:57 PM
Last Post: pugtk
  Diesal gauge/temp gauge pugtk 2 2,594 26-12-2013, 05:53 PM
Last Post: pugtk
