Threads: 374
38
Car Model/Spec: GTI 6
So looking at getting another motor: needs to be able tow 1500kg
Can't be too big either
Options at the moment are:
X5
Freelander 2
Discovery 3
Any other ideas?
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Mondeo, vectra, saabs etc can tow 1800kg.. Cheaper running aswell?
Threads: 48
XC90
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 42
28
5 series, e34 1800 kg, e39 2000 kg towing weights, E34 mam is 2000 kg so you can put 1500 kg behind it on a normal licence.
trouble with the bigger things is that without a towing licence you will not be able to tow much regardless of the capacity of the vehicle.
Threads: 25
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
One of the reasons I got the Vectra is mam of 2000kg caravan 1500kg so I can tow legally on my licence.
Threads: 374
38
Sorry! Forgot to add - needs to be four wheel drive to move horse trailers etc
Threads: 48
BMWs have been mentioned but I'd imagine anything with the 3.0 diesel engine is going to be a pretty decent tow car. Welshpug mentioned the earlier 5 series too
Threads: 25
If you need a 4x4 I've heard good things about Kia Sorreno's. Considerably cheaper than a Landrover ect. Just make sure the rear diff oil is changed regularly.
Threads: 42
28
you need a trailer test then, the mam of a 4x4 and a horse trailer is too high.
Threads: 29
Given 7 thank(s) in 7 post(s)
Cant be too big but considering a Disco? is that a joke?
I wouldn't touch anything LR with a barge pole, absolute money pits.
You 100% need a trailer test with a horse box, especially with any horses in it!
Threads: 120
35
Just get a landrover, theres a damn good reason they are renowned worldwide and hold their value like only a landrover does.
Disco 3 tdv6 is a good shout but heavy on juice, tyres etc etc probably be just as easier to save some cash and get a late disco 2?
Team Cyril
Threads: 29
The only thing you'd be able to tow on a standard license driving a disco 3 would be a tiny box trailer! 2.5tonne!!!
Threads: 47
14
Given 20 thank(s) in 20 post(s)
I Don't Have A 306.
(20-03-2017, 03:50 PM)Matt-Rallye Wrote: Just get a landrover, theres a damn good reason they are renowned worldwide and hold their value like only a landrover does.
Just as renowned for reliabilty issues. They are the boss off-road mind, but probably excessive for just a horse box in a slightly muddy field, especially since it would mean Ginge would need to get a towing licence.
81
Range rover p38
Threads: 128
21
Given 41 thank(s) in 38 post(s)
22-03-2017, 11:32 AM
(This post was last modified: 22-03-2017, 11:34 AM by toseland.)
(19-03-2017, 09:01 PM)ginge191 Wrote: Sorry! Forgot to add - needs to be four wheel drive to move horse trailers etc
without breaking the bank, LWB Grand vitara 2.0TD (the slightly rounder one), HDi 110 16valve engine so you know it's reliable, full hi/low range and selectable 4wd/2wd,
either that or the V6.
watch out for the auto hubs if they are the vac operated ones on the front, simple fix for about £30 to put some manual ones on for added economy..
2002-2005 have a 1600kg towing capacity, and a kerb weight of 1527kg.
the XL7 which is slightly larger but strangely lighter is weighted at 1450kg kerb weight and can tow 1850kg..
For something larger but older, look for a Ssanyong Musso.. they run on Merc Gwagon running gear with the OM diesel engine so absolutely bomb proof. Gear linkages are an issue but *i think* you can upgrade these from another vehicle (dont quote me)
/Toseland
Threads: 42
28
doesn't matter what the kerb weight is, its the gvw you need to look at.
Threads: 120
35
(22-03-2017, 11:51 AM)welshpug Wrote: doesn't matter what the kerb weight is, its the gvw you need to look at.
Kerb weight matters if you dont plan on being pushed around by whatever your towing.
Team Cyril
81
here we go... the standard plate weighting discussion begins!
Threads: 186
38
Car Model/Spec: MG ZR VVC
Dacia duster
Threads: 20
Car Model/Spec: gti 5 Turbo
Threads: 541
124
(19-03-2017, 09:29 PM)welshpug Wrote: you need a trailer test then, the mam of a 4x4 and a horse trailer is too high.
This entirely!!!!
Most of the 4x4s you'll be looking at have a gross weight in excess of 2.5T meaning that the max you'll be able to tow is just 1 tonne and no horse boxes are plated that low so you won't be able to tow it.
Remember that legally the weight is the plated gross (max) weight of the trailer and the plated gross (max) weight of the vehicle.
If you don't want to do a towing test then something like a 406 is your best bet for max towing weight as they gross at just shy of 2 tonne and have a 1.5tonne towing weight so you could tow a trailer plated up to 1.5 tonne.
Other option is to buy a transit sized horse box as they tend to be drivable on a standard license with 2 horses in
Threads: 26
Given 6 thank(s) in 6 post(s)
I'd go land cruiser, one of the most reliable jeeps you'll get imo.
Threads: 42
28
(23-03-2017, 01:46 AM)ConorTRG Wrote: I'd go land cruiser, one of the most reliable jeeps you'll get imo.
its not a Jeep
Threads: 26
23-03-2017, 07:43 PM
(This post was last modified: 23-03-2017, 07:46 PM by ConorTRG.)
(23-03-2017, 06:59 AM)welshpug Wrote: (23-03-2017, 01:46 AM)ConorTRG Wrote: I'd go land cruiser, one of the most reliable jeeps you'll get imo.
its not a Jeep
Pedantic much
Hardly, Jeeps are appalling, whereas landcruisers are one of the most indestructible and capable 4x4s on the market. Jeep is a brand vs Landcruiser is a model. Jap vs US. I could go on but i think you get the point.
Threads: 541
124
(23-03-2017, 07:43 PM)ConorTRG Wrote: (23-03-2017, 06:59 AM)welshpug Wrote: (23-03-2017, 01:46 AM)ConorTRG Wrote: I'd go land cruiser, one of the most reliable jeeps you'll get imo.
its not a Jeep
Pedantic much
No, pedantic would be arguing that the 1.25 fiesta should actually be called a 1.3.
With calling a Toyota a Jeep that's like calling an apple a tomato because they are both fruits when it's very obvious you wouldn't want that shit to be associated with your fruit salad.
