B4/Eibach with GTI6 Rear Axle
Just bought the B4/Eibach setup to go with my refurbed GTI axle with the 20/24mm standard bars on my HDI, what are the spring rates for the eibachs compared to the gti rear axle 20mm tb? Would this be fine or will the front now be a bit stiffer than the rear and should I try and get a 21mm rear tb?
Cheers guys
Anyone have any more info/advice? I know the spring rate for the 20mm tb is 135lbs but unsure on the eibachs? Have an idea its around 80-200lbs progressively digging out old threads from other forums.
Iirc having it softer at the rear will encourage understeer, so depends how hard you drive it and what you want from the chassis. Suck it and see, you may decide you like it.
Ive found the rear is softer and rolls more than the front, but have only had a 30 min drive of the car since fitting. Does seem pretty stiff/harsh though.
  Rear stub axle sizes weka 2 4,214 26-04-2019, 06:18 PM
Last Post: weka
  rear axle joe67 4 5,320 25-04-2018, 08:38 PM
Last Post: carlukepeugeot
  rear axle beam tube quality dsm482 10 8,769 22-12-2017, 02:01 AM
Last Post: dsm482
