Dashboard intermittent rev counter, no coolant temperature.
Hello!
Another problem now that im trying to sort out...
1.The RPM gauge is intermittent on my car. very occasionally it comes on but very juddery.
2. The coolant guague dosnt work.
Work i have done:
I have cleaned the sensor i was led to believe the RPM sensor (connects to the engine by the gearbox mounting, which plugs in round the front on a white 3 pin plug). which has now stopped it working completely.
I have replaced a blue plugged sensor just below the fuel filter housing. however the sensor i replaced it with only had one wire.
The original one had two wires. this has not worked. do i need to have a 2 wire sensor?
Forgot to mention it is the XUD TE 1.9 Phase 1 1996 D Turbo.
Any advice would be great!  Sleepy  Thanks Daniel
Anyone got any advice what I should replace or how I can test what has broken
Sent from my HTC One M8s using Tapatalk
Give the Rev sensor on the back of the engine a tap in and see of the gauge jumps to life
Check the plugs connecting the loom to the back of the instrument cluster are securely plugged in. While you have it out, check the rear of the circuit board for corrosion.
62k Diablo Phase 1 Gti-6:
Project Thread
  Fan always on + STOP light on dashboard arooscroocked 20 13,022 03-02-2018, 01:50 AM
Last Post: arooscroocked
  Dashboard bulbs LewisG 8 9,734 21-03-2017, 08:07 PM
Last Post: MattDanPug
  Dashboard bulbs Niall 21 15,249 21-03-2017, 12:08 AM
