cully's XU10J4RS
remember Biancas old engine the one the timing pulley cracked?
Ive been slowly gathering bits to rebuild it as another good spare engine ready to go
I bought Rocker Tom's old engine the one he killed at combe hoping there were some goodies i could save
but out of the whole engine he did a good job on it
head casting was scrap, block was scrap i managed to save the valves x16 and crank!
8 of the inlets and the crank i have put into this build
first off to build was the head
strip right back clean, check,true head,grind valves,new valve guide seals, pick out the best of the 32 hydraulic followers nd springs refit
[Image: 20160317_100043.jpg]
[Image: 20160317_182607.jpg]
next up was to chose which crank to use out of the two i have
to do this i bought a set of new std main and bigend bearings,
with these i used Plastigauge measuring tool to determine which crank journals were in the best condition,
to my suprise both cranks measured the same, both well within the bearing tolerances for the std shells on both mains and bigends.
so visualy i chose toms crank
[Image: 20160321_151245.jpg]
[Image: 20160321_151149.jpg]
[Image: 20160321_151343.jpg]
[Image: 20160321_151546.jpg]
[Image: 20160321_153802.jpg]
[Image: 20160321_154019.jpg]
with the plastigauge you cut a small section then clamp it with the bearing, the bearing will squish the waxy section giving you a width to measure
you take the measurement and refer to the bearing manufacturers tolerance if your in the tolerance all is good
[Image: 20160321_154028.jpg]
[Image: 20160321_155917.jpg]
[Image: 20160321_154429.jpg]
my choices were made on the crank now do i go race bearings.......
yup i bought
King race bigend bearings
Malhe main bearings
Coetze C20LET rings
just be warned the pictures jump back and forward in time Wink
block,crank,rods were all cleaned ready for assembly
which i have been doing over this week
[Image: 20160503_203931.jpg]
[Image: 20160504_195517.jpg]
[Image: 20160505_193032.jpg]
[Image: 20160505_202455.jpg]
as of this evening im at a stage where im ready to fit the sump!
[Image: 20160506_200423.jpg]
GTI6 Info
Christ I didn't realise you went through all that! I thought you were just changing rods!! Cracking effort mate
forgot to clean the sump up, so put it through my parts washer Wink
1 cycle then wirebrush in a drill to break up the lumps left then onto a final cycle of wash
now to fit it to the engine block Smile
GTI6 Info
I now have a freshly assembled refurbished short motor!
i cant assemble any more untill i start buying gaskets so this project is on hold now untill probably june
GTI6 Info
looks epic man as always. i love this project just the details man. i love the details
ordered some more gaskets
will be putting the head on this soon Smile
GTI6 Info
waaaaat!
you copied my orange engine!!
i should really get another engine and start making it pretty.
(29-06-2016, 02:38 PM)welshpug Wrote: waaaaat!
wouldn't know are you building something not seen a project thread Tongue
last one was red hamerite this time its industrial warning RED on a white base to make it bright Wink
GTI6 Info
ha, I've got a project thread Tongue
just not updated in a while as I haven't got any WIFI at home to do a decent update.
mine is ORANGE though, guess yours looks more red in person?
[Image: 27249010236_3c540bc264_c.jpg]20160526_205150 by WELSHPUG, on Flickr
cool where's your project thread would like to have a read Smile
GTI6 Info
just realised the last update wasn't that long ago.
http://306oc.co.uk/forum/showthread.php?...010&page=3
  Cully's Bianca 6 R150 YVM cully 994 862,451 13-01-2019, 04:04 PM
Last Post: cully
  Cully's Electric car ..T project cully 144 98,850 16-04-2016, 04:14 PM
Last Post: cully
