compbrake quickshift fitting / adjustment
got a compbrake quickshift
grubscrews are no good and collars moved within about 3 seconds of fitting it so took it straight off.
This was a while a go, and im considering putting it back on
Have drilled the offending grub screws out, becasue of course they round as soon as they smell a hex key
so
whereabouts do i want this badboy before i weld the collars in position?
too short and I know its going to be an arse getting into gear, too long and whats the point?
input appreciated
Get a pic of the item mate.
If it's the one I'm thinking of its fit for the bin.
Compbrake still is shit/borderline dangerous
this is the happy chappy >>>
[Image: p-956-cmb0331_pug-206-306-qs_3.jpg]
the main issue is the collars are wanking about on the shaft, sleeve the shaft up to the size of the collars, and the grub screws should work better.
I'd personally put it where the standard one was, the shift length is about right as standard if there's no play in anything, half the play will be on the subframe quadrant.
(10-03-2016, 02:22 PM)welshpug Wrote: the main issue is the collars are wanking about on the shaft, sleeve the shaft up to the size of the collars, and the grub screws should work better.
yeah the collars move and its turns to mush
so, fix it so the rose joint is where the original ball was? or a different position for similar throw.
i can't just fit and fettle, as the collars are all goosey loosey now ive drilled the cheesy grub screws out. gonna zap them in position with the firestick
I can measure mine? Or you can come try mine, then measure?
I welded the one underneath and used spacers for top one so if needs be can still remove it.
  compbrake adjustable top mounts philip r 5 3,635 25-07-2015, 04:14 PM
Last Post: Pompey306mark
  quickshift connorp 18 9,760 18-06-2015, 06:04 AM
Last Post: kentiiboii
  quickshift gearbox type mossy1985 5 3,195 09-01-2015, 10:54 PM
Last Post: cully
