16-06-2015, 12:18 PM
http://www.ebay.co.uk/itm/PEUGEOT-206-30...51a17ba541
is this an alright budget quickshift or a no go??
quickshift
16-06-2015, 12:28 PM
They're fine generally, just sometimes the brass fittings come loose so need gluing or bigger grub screws
16-06-2015, 12:47 PM
a bit shit really, not very well executed, always come loose.
16-06-2015, 12:54 PM
I think they would work much better if the gearstick was sleeved so it fits tighter in the spherical bearing.
WELD THE lady garden!
16-06-2015, 02:39 PM
How exactly do you put the stick through the ball? Do you have to remove the knob and the plastic off the top?
16-06-2015, 03:16 PM
plastic? just pull the knob off, cut the plastic ball away and slide the stick through the spherical joint with a collar each side, well not so much slide but dick in a shirtsleeve kinda thing.
16-06-2015, 03:20 PM
i think he meant the plastic sleeve the knob sits on?
I drilled a couple dimples in the shaft for the grub screws to sit in (on the compbrake QS on my ax)
16-06-2015, 03:23 PM
never seen that on a 306, only later 406's with cable shift.
my 306 has it, wierd white plastic sleeve with a ridge down either side (to stop the knob rotating on the shaft) does this just pull off like the knob? I didnt want to force it and shatter the damn thing
16-06-2015, 03:56 PM
(16-06-2015, 03:46 PM)thododd Wrote: my 306 has it, wierd white plastic sleeve with a ridge down either side (to stop the knob rotating on the shaft) does this just pull off like the knob? I didnt want to force it and shatter the damn thing They don't seem to come off, shattered when I tried anyway.
16-06-2015, 04:08 PM
I welded the collars on mine either side if it helps
It was already fitted previously but was a bit poo, didn't hold up 5 mins on track.
16-06-2015, 05:42 PM
(16-06-2015, 03:23 PM)welshpug Wrote: never seen that on a 306, only later 406's with cable shift.I think he means for the lift reverse on a gti6. I had to slice mine off and tiger seal it back on with a few cable ties.
17-06-2015, 09:50 AM
The cheaper way for quickshift is to extend the length of gear stick around 2"
Shift feeling are better !
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted ![]()
17-06-2015, 11:43 AM
(17-06-2015, 09:50 AM)maxzy Wrote: The cheaper way for quickshift is to extend the length of gear stick around 2" Drugs are not ok
17-06-2015, 09:02 PM
(16-06-2015, 12:18 PM)connorp Wrote: http://www.ebay.co.uk/itm/PEUGEOT-206-30...51a17ba541 I got a pug1off one a couple of years ago. Never skipped a beat. Seems solid and im sure it was cheap as.
17-06-2015, 09:05 PM
(16-06-2015, 04:08 PM)Lwilliams Wrote: I welded the collars on mine either side if it helps mine are welded too
17-06-2015, 11:51 PM
Just fitted this to the 306 HDi. Hasn't shortened the shift by a huge amount, but its noticeable. Also gives the change a very firm feel. Took 20 minutes to fit as it's a direct replacement.
Unsure if it will fit a Gti6. And definitely won't fit cars with cable gear linkage, suitable for mechanical type only. http://m.ebay.co.uk/itm/DIRENZA-PEUGEOT-...0952534271
Resident cat lover
18-06-2015, 06:04 AM
(17-06-2015, 11:51 PM)Pebbles167 Wrote: Just fitted this to the 306 HDi. Hasn't shortened the shift by a huge amount, but its noticeable. Also gives the change a very firm feel. Took 20 minutes to fit as it's a direct replacement.I think this would fit a gti6, you just have to make the lift reverse attach somewhere.
| compbrake quickshift fitting / adjustment | zx_volcane | 5 | 3,833 |
10-03-2016, 02:34 PM Last Post: Piggy |
| quickshift gearbox type | mossy1985 | 5 | 3,393 |
09-01-2015, 10:54 PM Last Post: cully |
