Any one got a hdi engine lying around?
I need a measurement  of how far the head hangs over the block
Just for turbo clearance really down the back
what do you mean overhangs the block? ive got one sitting in my current project that i need to whip out at some point soon. im sure i can get whatever measurements you need man
The head is wider back to front than the block.
The head sits 20mm or so proud off the block.
Just trying to Gauge how much room I've got for an actuator
I'll try and remember to check the one sat in the garage tomorrow.
If you could and grab a fewpics pretty please.
My plate will be here for the adapter, Try not to f*ck this one up
Due to the casting... The overhang varies.
27mm on that very first edge...but generally about 22mm from the flange for exhaust to the block edge
Spot on. Repped Smile
Gives me a nice amount of room to fit an actuator on
Mint, one less thing to do. Big Grin
