Brake light switch FIXED
Rainbow
Hello the brake light switch works on my spare 306 hdi. But when you pull the switch out more it clicks each time in to place. You then release the brake pedal so the switch a just to the pedal.
It works for a short time but the switch ends up going back a few mm to far. But if you hold the brake pedal back up foot underneath a few mm the brake light switch works.
So I'm thinking what's the best thing to do here with the switch working but this problem with it moving.
Thanks
Tape it.
Surely the 'lumps' on the switch have worn away so a replacement switch is the proper fix? Tape seems like a cheaper solution though lol.
Yeah just bang a new switch in. They're a bastard to get to and a new switch is less than a tenner. Had to do one on mine last year same issue.
Mine went christmas time past year. Proper horrible to get to. If you need to dismantle to bodge it, you might as well fit a new one.
So is there a good guide on here with pictures.
The switch needs changing for a new one for sure.
I drop the steering column when I do them and there not to bad to do. I did 1 at FCS last year for someone.
Thanks given by: Welshy_Pete
Yeah as frosty says. Best thing I to drop the colum. I also remove the right hand side air vent and gubbins as I've got small arms. I can get to it with both hands then.
You're not a real 306 owner until you do the brake light switch lmao
(17-02-2016, 03:15 PM)Matt Wrote: You're not a real 306 owner until you do the brake light switch lmao
Couldn't agree more Smile
I've got massive hands and had to take the dash out... Never ever ever again
I'll find someone else to do it
I had to fist my dash. Was elbow deep in dashboard to get to it lmao
I have passed the test I have done the brake light switch yesterday 5mins out then 10mins back in.
(16-02-2016, 10:35 PM)Frosty Wrote: I drop the steering column when I do them and there not to bad to do. I did 1 at FCS last year for someone.
Yes your right I managed to sort it in the end.
(17-02-2016, 06:58 AM)bashbarnard Wrote: Yeah as frosty says. Best thing I to drop the colum. I also remove the right hand side air vent and gubbins as I've got small arms. I can get to it with both hands then.
I managed to do the job with one hand changing the brake light switch. The size of arms makes a difference for sure.
Yeah doesn't take long to do, just a pita to get to
  Brake light switch parts exploded view pug306driver 11 9,339 13-12-2021, 06:11 PM
Last Post: Mighty306
  Brake light switch pug306driver 10 7,893 14-10-2021, 01:18 PM
Last Post: pug306driver
  Fixed please delete Leemus 11 7,124 18-05-2017, 08:01 PM
Last Post: Leemus
