XU10 oil gallery tappings
Anyone got a photo of an XU10 undressed on the front? I'm led to believe there are two tappings that can be used for oil gauges, but I can only find this pic in my archives. I need to fit two sensors.
[Image: IMAG0076.jpg]
As you can see one is marked up, anyone know where the other one is or got a photo with them marked up??
A is the oil pressure light switch iirc.
Cheers
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Use the one you have marked as M16 blank
On mine i use the original one above the oil filter for the dash switch (marked A on yours) and the blank for a pressure sensor for my gauge.
im using the std sensor at A, and I have a remote tapping for a sensor and switch at the M16 blank
the blank is 16 x 1.5mm Wink
[Image: 20150813_094615.jpg]
GTI6 Info
Anyone know what the thread at A is? I'll probably double that up, and put the temp probe into the blank. I don't want it on a dead leg particularly.
Shit the bed cully those sensors are massive. I had the same arrangement on my Rover for the oil pressure but tapped the sump plug out for temperature.
I wonder if i still have the sensors off my old block.Hmm
Edit: M16x1.5 again accordings to servicebox. Smile
whats wrong with the oil temp sensor in the sump pan?
GTI6 Info
Nothing wrong with it per se, but I already have a dual digital pressure/temperature gauge from S.P.A from my previous car, and intend to hook both sensors up to compliment it - you can program alarm lights for P and T.
More a case of using what I have already. Plus handy if i'm in the passenger seat as opposed to just drivers. Smile
  XU10 J4D/Z / RFT? thiscocks 3 4,585 06-08-2014, 09:40 PM
Last Post: welshpug
  Surging xu10 when cold sherman306 2 2,657 17-07-2014, 10:53 AM
Last Post: sherman306
  XU10 thicker head gasket (see newbies too) Ephrem 6 5,974 11-07-2014, 03:49 AM
Last Post: Dave
