XU10 thicker head gasket (see newbies too)
As per my newbies thread earlier today, I need a 2mm head gasket for a race-tuned, all steel, 306 XSi 8v engine. I've been quoted £280 for two custom made Cometics by Pug1Off.
Anyone know a UK/European fabricator of quality head gaskets?
Anyone any experience of decompression plates which can be used with standard thickness gaskets to make up the difference?(http://www.ferriday.co.uk/decompression-plates/)
Cheers
Ephrem
2mm ?!
Cheaper to take some material off the pistons and use a standard £40 mls peugeot gasket!!
(10-07-2014, 09:23 PM)welshpug Wrote: 2mm ?!
Yes indeed and I even have said gasket (306 GTi-6) to hand. Not sure if you can do it with accralite high compression pistons but happy days if you could. I'll run it by the engine builder, thnx
Asking for a thick head gasket sounds more like issue that needs addressing as any weak points will soon become apparent,
Just seen your other post,
So the engine builder has got you to buy high comp pistons...then wants you to get a ruddy great thick gasket to reduce the comp down?! Bit random
(10-07-2014, 10:27 PM)Piggy Wrote: So the engine builder has got you to buy high comp pistons...then wants you to get a ruddy great thick gasket to reduce the comp down?! Bit random
Not original builder. He has inherited the engine and I've asked him to change it from a full-on high compression twin 48s race engine with narrow power band 6000-8000rpm to a more user-friendly injected engine. Reducing the cam will increase the compression even more and so she needs a thicker head gasket to compensate. That's as I understand it anyway
Also with a 2mm thicker head gasket, it'll throw your cam timing all over the place.
  XU10 oil gallery tappings C2K 5 3,243 15-11-2015, 10:29 AM
Last Post: C2K
  head gasket change si124 1 1,864 16-03-2015, 03:09 PM
Last Post: bashbarnard
  XU10 J4D/Z / RFT? thiscocks 3 4,042 06-08-2014, 09:40 PM
Last Post: welshpug
