brake light switch
Hi all,
there's probably a thread on here already, but what's the best way to access this switch for fitting a lock nut or something?
Mine keeps working out of adjustment, so pressing the clutch flickers the brake lights. - it has a small tie-wrap round it at the mo'
thanks - -
Hate Housework!
They are just a push fit. Best to drop the steering column and then access is a lot easier to it to check its in right
cheers (mentally reaches for spanners)
Hate Housework!
When I replaced mine I dropped the steering column and pulled out the drivers air venting. Heat access and you can use the vent hole to actually see what you are doing/give it an extra hand from behind Smile
It's an arse whatever you do. Hate that bloody switch
P1 XSi track car
2.4 LWB T4
Fuel tank out, 2 fuel elbows, drive shaft on a primera, all better than this stupid switch.
Took 2 of us over an hour in the freezing cold last year.
Really? It took me 15minutes by myself with fat hands....
It really isn't that bad to do if you drop the steering column. I did the switch on ferry's car at FCS this year
thinking, if I gat at it, I will extend the wiring and drill in a H/D footswitch into the brake pedal itself. :/
Hate Housework!
  Brake light switch parts exploded view pug306driver 11 9,379 13-12-2021, 06:11 PM
Last Post: Mighty306
  Brake light switch pug306driver 10 7,941 14-10-2021, 01:18 PM
Last Post: pug306driver
Rainbow Brake light switch FIXED Welshy_Pete 13 8,121 20-03-2016, 02:17 AM
Last Post: Matt
