Start up
Start up
The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking.
Sometimes almost seems like a dead battery.
Just the first of many problems to sort haha
1. Check battery voltage at rest and while cranking.
2. Check to make sure battery cable that connects to starter is in good order and correctly fastened.
3. Check voltage drop between battery negative and engine block while cranking.
4. Check voltage drop between battery positive and starter (or alternator) positive terminal.
5. Report results back here for analysis and further crunching of available data.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
Man looks like I need a tester then! Will have to order one tonight
(20-08-2015, 05:12 PM)Matt Wrote: Man looks like I need a tester then! Will have to order one tonight
Or ask your fellow islander who has sheds full of tools?   Idea
Okay when you free Tongue think I'm on some lates this weekend. Starting at 5 Saturday and Sunday
(20-08-2015, 08:35 PM)Matt Wrote: Okay when you free Tongue think I'm on some lates this weekend. Starting at 5 Saturday and Sunday
I'm free for the next 2 weeks!
Just let me know where and when
Well I'm free today. Till 5
I'm off all day Wednesday?
(23-08-2015, 12:24 PM)Matt Wrote: Well I'm free today. Till 5
If you'd messaged me i coulda been round you giant vagina. wednesday it is.
Give the starter a good whack with a hammer and report back
I swear I messaged you! Oops haha
I'm gunna take a look at the starter tomorrow. Engine didn't run for 3 years so could be a starter issue
(23-08-2015, 03:24 PM)Matt Wrote: I swear I messaged you! Oops haha
Ah, phone is in pieces at the moment; facebook only x
Ahh yeah, remember seeing your status come to think about it haha
(20-08-2015, 02:58 PM)Matt Wrote: The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking.
sounds like a flat battery?
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
Or sticky starter /solenoid
any news on this?
306 HDI
stage 1+ remap
Will be checking it over with Ginge in the morning Wink
