| The following warnings occurred: | |||||||||||||||
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
Start up - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Start up (/showthread.php?tid=31644) |
Start up - Matt - 20-08-2015 The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking. Sometimes almost seems like a dead battery. Just the first of many problems to sort haha Start up - Janne L - 20-08-2015 1. Check battery voltage at rest and while cranking. 2. Check to make sure battery cable that connects to starter is in good order and correctly fastened. 3. Check voltage drop between battery negative and engine block while cranking. 4. Check voltage drop between battery positive and starter (or alternator) positive terminal. 5. Report results back here for analysis and further crunching of available data. RE: Start up - Matt - 20-08-2015 Man looks like I need a tester then! Will have to order one tonight RE: Start up - ginge191 - 20-08-2015 (20-08-2015, 05:12 PM)Matt Wrote: Man looks like I need a tester then! Will have to order one tonight Or ask your fellow islander who has sheds full of tools?
RE: Start up - Matt - 20-08-2015 Okay when you free think I'm on some lates this weekend. Starting at 5 Saturday and Sunday
RE: Start up - ginge191 - 20-08-2015 (20-08-2015, 08:35 PM)Matt Wrote: Okay when you free I'm free for the next 2 weeks! Just let me know where and when RE: Start up - Matt - 23-08-2015 Well I'm free today. Till 5 I'm off all day Wednesday? RE: Start up - ginge191 - 23-08-2015 (23-08-2015, 12:24 PM)Matt Wrote: Well I'm free today. Till 5 If you'd messaged me i coulda been round you giant vagina. wednesday it is. RE: Start up - Paul_13 - 23-08-2015 Give the starter a good whack with a hammer and report back RE: Start up - Matt - 23-08-2015 I swear I messaged you! Oops haha I'm gunna take a look at the starter tomorrow. Engine didn't run for 3 years so could be a starter issue RE: Start up - ginge191 - 23-08-2015 (23-08-2015, 03:24 PM)Matt Wrote: I swear I messaged you! Oops haha Ah, phone is in pieces at the moment; facebook only x RE: Start up - Matt - 24-08-2015 Ahh yeah, remember seeing your status come to think about it haha RE: Start up - craig306 - 25-08-2015 (20-08-2015, 02:58 PM)Matt Wrote: The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking. sounds like a flat battery? RE: Start up - Paul_13 - 25-08-2015 Or sticky starter /solenoid RE: Start up - craig306 - 26-08-2015 any news on this? RE: Start up - Matt - 28-08-2015 Will be checking it over with Ginge in the morning
