Fitting Side Skirts
Would any of these rivets do? Not too sure what im looking for.
http://www.amazon.co.uk/Screw-Panel-Clip...6mm+rivets
http://www.amazon.co.uk/Nissan-Honda-Int...6mm+rivets
Cheers
Anyone?
When i have re fitted side skirts i have used screws so there easier to take off in the future if need be
Cheers Frosty! Just normal screws? They hold it on well enough?
self tappers?
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
self tapping screws and some sealent
Plastic rivets won't work down there tbh, could use metal rivets like they did from the factory but screws will be easier and obviously allows you to remove them again if necessary.
So can I just use normal M6 screws then? or do you need a washer or bolt on the other side of the skirt? Don't want to take the skirt off and find ive bought the wrong parts lol
you can use washers but you shouldnt need to with self tappers, no need for bolts etc
So just self tapping screws is all I need?
(07-08-2015, 02:43 PM)MY95 Wrote: Cheers Frosty! Just normal screws? They hold it on well enough?
Yeah screws with little heads on them so they don't show up. Drilled some new smaller holes, they seem to hold well enough
  Removing and Refitting Side Skirts JTaylor2005 19 12,592 03-03-2018, 09:09 AM
Last Post: JTaylor2005
  Side skirt extensions and rear diffuser side pieces Slam Wagon 38 18,659 19-11-2014, 05:56 PM
Last Post: welshpug
  Can you fit Ph3 side skirts on a Ph2? Nathan1305 4 3,442 09-04-2014, 09:56 PM
Last Post: Nathan1305
