Side skirt extensions and rear diffuser side pieces
Thought i would share the latest addition, rear defuser is next but i might try and find some heat resistant stuff for that.
[attachment=17803]
[attachment=17804]
Looks good! Got any pictures of it underneath?
Trying to improve the under-floor aero?
62k Diablo Phase 1 Gti-6:
Project Thread
Glad to see I am not the only one thinking of a rear diffuser and these side aero fins
Can't really see it, too shiny lol
Am I missing something?
Ive only done it as a strip down each side, could do it with a couple of sheets to cover the entire underside if you wanted to. It would just be trying to fix them in place as its pretty flexi stuff, also not particularly heat resistant so the exhaust could be a problem.
So today i had nothing to do so i got on with a little more aero. The plan is to eventually make a rear diffuser, I've already got a rough cut piece of plastic for that but for now it was just to get the side pieces on.
got the idea from here CLICKY
Though they looked pretty smart and fairly easy to make. And for once i took pictures as i went to heres a how to....
Step one: using cardboard or paper make a template for your pieces
[attachment=18702]
Step two: Once your happy with your shape trace it onto your plastic or metal and cut it out
[attachment=18703]
[attachment=18704]
Step 3: cover or spray your pieces if you wish to do so
[attachment=18705]
Step 4: now you need to align your pieces and drill the holes for the brackets
[attachment=18706]
as i said i intend on fitting a diffuser so have used an off cut of the plastic under each bracket to make sure they dont need to be altered when that is fitted.
Step five: line up and mark your pieces to be drilled, remember measure twice cut once. drill your holes and test fit them
[attachment=18707]
Step six: paint your hardware, silver bolts are easy to get hold of but not always pleasing to look at
[attachment=18708]
Step seven: once all your paint is dry, refit your pieces and admire your handy work
[attachment=18709]
[attachment=18710]
Well its interesting thats for sure.
Different i know, and probably disliked by most. Oh well, they can deal with it.
Subtle but smart. Thought about building a full rear diffuser for my car, but after a lot of consideration, it was deemed aerodynamically worthless without an entire sub-sheet.
Looks awesome though Smile
My plan is to go from the boot floor behind the beam and then flat to the bottom of the bumper, should make a bit of difference as the rear bumper is just catching it all atm. I want to put some fins on but figuring out the best way without loads of brackets and screws.
Be interesting to see how this goes...I been drawing up plans for underfloor stuff for a while.
What material you using...where you get it from?
Think its just acrylic stuff i think, not too sure tbh, its not heat resistant but ive got heat wrap and checked my exhaust temps after a run an it shouldnt be an issue, ill keep a close eye on it when i fit it. Theres a local building plastics place. Its actually a packing sheet, 2mm in black rather than 3mm in white, so better for me and it was 1/3 of the price. Im keen to see where you get with a sump guard piggy, im going to start lookig at sorting one when after this.
So today this happened...
[attachment=19014]
Ummm.... Confused
Haha, bit lairy but i like it
Saw this on IG. Love it. Right up my street!
defiantly interested in seeing how a full rear defuser would look
The first mock up is in place, not sure where to go with it now.
[attachment=19441]
That looks good.
I think there's a lot of potential on a 306 for a decent diffuser, there's an awful lot of space behind the bumper. Looks a good start, you clearly looked at all the same project threads as me, as that all looks very familiar!
[Image: sigcopy-1.jpg]
Barely read project threads tbh, try not to look within the forum for inspiration.
Going to mock up some fins for the centre soon, see what they look like. Nearly out of plastic now though and i cant get another sheet.
great stuff. now put them into production for the rest of us to buy!
Not on this forum, elsewhere, but the guy did exactly what you've done for skirts and rear corner pieces.
oh ok. bmw one i linked up top? that was a quick google for diy aero stuff. then found the plastic sheeting which fitted the bill perfectly. the problem with the diffuser (if you can call it that) at the moment is its got a really awkward bend to fit to the bumper on the right hand side, where it has to bend in two directions to come down from the floor and then line up against the bumper, not alot i can do about that i dont think unless i cut it and make it almost three part.
My idea was to cut a decent chunk out of the middle of the rear bumper and have a fairly 'traditional' diffuser. It'd be a bit boxy unless you had some fiberglass skills, or a clever way of bending the sheet.
Wait... Come down from the floor? You don't want to be coming down towards the back of the car, surely?
dont want to be going flat either, unless you take it all the way to the fuel tank, which makes fixing tricky and working it around/over/through the beam. and my sheet wasnt big enough to go that far anyway. this was basicly to stop the rear bumper being a massive air brake. so mine comes flat off the boot floot as there is a brace going across on the estate.
Surely you wana come under the beam and tank to the floor of the car?!
That huge exhaust gap is guna kill the aero a bit too, no?
So easy to make an exhaust blown diffuser also!
Long as you can make it withstand the heat, would be win!
(09-10-2014, 10:01 PM)Piggy Wrote: Surely you wana come under the beam and tank to the floor of the car?!
Boxing the exhaust in is probably going to melt something though.
Project Thread
  Rear passenger side door won't open DonGonzo 0 2,427 19-10-2020, 10:25 PM
Last Post: DonGonzo
  Removing and Refitting Side Skirts JTaylor2005 19 12,852 03-03-2018, 09:09 AM
Last Post: JTaylor2005
  Hdi sear side airbags toseland 8 5,765 30-07-2016, 09:11 AM
Last Post: Toms306
