Camber/axle swap
Hi, 306 hdi has major camber on a rear wheel, the tyre is not far off touching the inner rear bodywork so obviously the beam needs replacement. Couple of qustions : is it safe to use in the short term as it's my only motor ?, would an estate beam be the same fitment as thats all I can find locally second hand ?
Cheers!
What year is the replacement and what year is the car?
They will fit just minor differences as long as they're both disc beams
as paul has said phase 1-2 have different mounting rear arms to phase 3 but most things should be the same.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
  Repairing rear axle and camber? JTaylor2005 7 3,901 07-08-2015, 09:46 PM
Last Post: miles
  Negative Camber Snell 16 8,339 18-01-2015, 05:35 PM
Last Post: Snell
  306 Front and Rear Camber devilchris 9 7,109 30-04-2014, 04:30 PM
Last Post: Slam Wagon
