306 Front and Rear Camber
I used the "search" button but I found the old threads, with photos and links do not work offline.
The title is clear.
I'm looking for my 306 S16 something that allows me to adjust the camber front and rear.
for the front axle front I believe that the solution is this:
- PAIR Peugeot 306 Adjustable Top Mount: Compbrake Price: £151.20
[Image: pug-306.jpg]
http://www.corbymotorsport.com/pair-peug...11324.html
-Bakerbm 306 Adjustable Top Mounts £175 + VAT
[Image: 306-adj-top-mounts.jpg]
http://www.bakerbm.com/306.php?data=306adjtopmounts
- CompBrake PEUGEOT 306 ADJ. TOP MOUNTS (PAIR) £109.99 (gli stessi dei primi ma dal produttore)
http://www.compbrake.com/--53.html
- Spoox Motorsport Peugeot 306 Eccentric Strut Top Mounts £135.00
[Image: spoox-motorsport-peugeot-306-eccentric-s...mounts.jpg]
http://www.spoox.co.uk/en/front-suspensi...ounts.html
- Top mount, Peugeot 306, adjustable 110 €
[Image: 508_0.jpg]
http://www.raceparts.cc/product_info.php...anguage=en
for the rear axle I have no idea what to look for and how ...
There is a group buy for Baker BM stuff so you could get the top mounts slightly cheaper if you get in on that.
You can get negative camber trailing arms for the rear, and you'd have to rebuild your beam to fit them. This isn't adjustable like the front would be though.
[Image: 20120704_212316.jpg]
(01-03-2014, 06:48 PM)Ben Wrote: There is a group buy for Baker BM stuff so you could get the top mounts slightly cheaper if you get in on that.
This.
The eccentric top-mounts also offer limited adjustability, due to the fact that the castor increases with the camber. The beauty of the camber adjustable top mounts is that you can run whatever you want without affecting the castor.
the support of the gearbox?
I have to leave one of the 5-speed or 6-speed take what the?
(04-03-2014, 12:16 PM)devilchris Wrote: the support of the gearbox?
Yes. Couldn't agree more.
You need, milled trailing arms and stub axels for rear camber . not cheap
Yeh camber adjustable top mounts but the rest is a problem.
opsss .. I'm wrong section!
silly but out of the baker and comp top mounts what is the better one not quite Shure
Baker imo as its fixed caster.
  New Disks and Pads - Front & Rear Recommendations MisterGTR 6 4,112 10-09-2016, 08:15 AM
Last Post: cully
  Disconnecting rear brake lines at the front Iaitoo 21 10,986 04-06-2016, 08:22 AM
Last Post: pug306driver
  GTI6 rear beam and front legs Frankwood 1 2,028 10-05-2016, 08:09 PM
Last Post: Mattcheese31
