Xud to hdi clutch. Flywheel question.
So im putting Lus motor on the ramp soon to do the clutch and turbo. I have a good clutch from a hdi along with all bits. Inc cable. Is the flywheel sensor the same pickup? Or will we loose the rev counter. If so can I combat this somehow??
Im pretty sure rev counter pickup is different
Shit. Any chance of using the xud flywheel then??
From my experience hdi sensor on top gearbox like most petrol crank sensors and xud on back block. I have a 180 flywheel with push clutch on ma van. but had to grind off tabs on fly till only 2 left so rev counter would work lol
Well ill have to get them side by side and compare.
HDi flywheel is something like 38-2 toothed setup, XUD is just a simple 4 tooth affair
If using an angle grinder to remove the teeth - be sure that you don't get the flywheel hot, just "tickle" the metal slowly, to reduce heat buildup.
  hdi flywheel +clutch to xud daveylennon93 8 5,194 11-07-2014, 01:58 PM
Last Post: mr_fish
  Clutch question clarkey2010 5 3,229 04-06-2014, 10:08 PM
Last Post: clarkey2010
  engine swap, clutch question 205diesel 14 10,085 10-06-2013, 08:38 PM
Last Post: 205diesel
