Fabric for roof lining
So this is something I know literally nothing about.
I would like to redo the taty roof lining in my 205
I need to know what sort if fabric is used for this and how to apply it , I guess I just use a spray on adhesive like used on carpets ?
Wheres the best place to buy the fabric from ?
And whether I need to pull off the original grey lining which isn't sagging but since I didn't bother taking it out when I resprayed the car its got fairly covered in red paint
Thanks in advance
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
http://306oc.co.uk/forum/showthread.php?tid=26118
The fabric is less important but the glue is important as any old spray adhesive will sag with heat.
Thanks for the link don't know how I didn't see it before
I'll get some Trimfix and some fabric and give it ago
(27-05-2015, 05:57 PM)I\m andyyy Wrote: Thanks for the link don't know how I didn't see it before
How did you get on with this
If youve not done it yet if you can get a mate to help hold the fabric or drawing pins and start at the front around the interior light and work one side front to back half way then do they other side I found it easier I tried starting at the side and ended up pulling it off 2 or 3 times
  door card fabric Magenta Sunset 3 3,988 13-08-2018, 01:02 PM
Last Post: pug306driver
  Roof lining Adam-m-h 53 37,018 18-08-2015, 03:17 PM
Last Post: Adam-m-h
  Door fabric Calpin 2 2,698 18-01-2015, 02:14 PM
Last Post: Calpin
