rear beam rebuild bits
I know that a few people bought a bunch of the washers, bolts, seals etc for rear beam a while back...
Anyone got any left??
And recommend some bearings??
Smile
Stef would prob be the best man to speak to on this.
I would say for the bearing get them from peugeot if they still do them
Genuine bearings are available around £15 each, bolts are around £1 each plus nuts etc I think it works out at around £130 for both sides plus your trailing arm shafts which are £100 each from pug.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
£230 just for parts!? :-o
http://www.ebay.co.uk/itm/ACHSTRAGER-CIT...27da0a11c1
what about that!?
Try £330 and a new calculator Wink
(20-05-2015, 09:44 PM)Niall Wrote: Try £330 and a new calculator Wink
ahh I misread that it was PER side!  Nospeak
stuff that.
can get refurbed for less surely!?
long time ago since i checked peugeots prices but its never pretty. Id advise going with a well known manufacture of parts im affraid you get what you pay for and imo if they can supply a tube and bearings etc for that id question the quality.
05' Evo 9 IX GT
Team eaton.
http://www.ebay.co.uk/itm/120976019232
used a few of those without issue, with the euro getting a hammering its a no brainer IMO.
I've got a few fasteners and bits spare too, so strip it apart and let me know if there's any you need, there's no point ordering any till you've got it apart as you might only need on or tow, or ALL OF THEM!
http://www.ebay.co.uk/itm/Peugeot-306-Ci...19fabe9f21
You realise Piggy that Stef does refurb beams for less than the parts cost from Pug new right?
do you not plan to change the shafts? they may look good but untill you measure them you cant be sure
05' Evo 9 IX GT
Team eaton.
(20-05-2015, 09:48 PM)welshpug Wrote: http://www.ebay.co.uk/itm/120976019232
Thanks fella.
I need the ARB seals for SURE! and the plastic caps have all but had it tbh
(20-05-2015, 09:50 PM)Niall Wrote: You realise Piggy that Stef does refurb beams for less than the parts cost from Pug new right?
no idea.
I assumed he would have said a price if he wanted
Dont wana assume anything
(20-05-2015, 09:51 PM)Stef205 Wrote: do you not plan to change the shafts? they may look good but untill you measure them you cant be sure
possibly. If needs be I will obviously.
The beam has done about 45k miles.
I removed it personally from a cabby couple years ago and it had done 30k.
Its only that when I swapped ARBs a month ago, the ARB was a bit orange and damp. The ARB seals were dead.
So would like to think just the bearings. There is no camber what so ever and no play and they are both nice n free n noiseless!
what you think to this stef? -
http://www.ebay.co.uk/itm/Peugeot-205-30...3f4ce96ad0
not yet had an used beam apart that had usable shafts regardless of mileage, its age that does it I.m.e.
also what its come off, a 5 door with skinny torsion bars will be in much better condition than an xsi/s16/gti6/rallye/dturbohdi beam.
Its personal choice should you go for genuine or not. I warrant all my rebuilds for 2 years should you want me to rebuild you one. I do them at £280 for forum members than that comes with new bolts and arb seals and bushes. Exactly as niall and sam had a few weeks ago.
As said the shafts are normally dead and arent worth taking the risk on used items, I always replace them
05' Evo 9 IX GT
Team eaton.
I'll be in touch Stef some point in the near future. I need a 205 beam and a 306 beam
Thanks fella.
no idea.
Well that's just weird, typed out a reply and deleted most of that quoted crap, yet when i hit post that ^^^ appeared, ie all of the quotes and none of the reply...
I'll summarise: Piggy made an amusing self-contradiction (assuming), i took the piss a bit and helpfully pointed out the link in Stef's sig and suggested he start reading the forums with his eyes open. Wink
Edit: I know you've been feeling down of late, pigger, so in case you feel i'm just being nasty, here's some kisses. Xxxxx
Xox
Heart
(20-05-2015, 10:37 PM)welshpug Wrote: not yet had an used beam apart that had usable shafts regardless of mileage, its age that does it I.m.e.
as said above...
it was on a cabby that had done 30k. (i done 15k on that)
When me and jamie first had it apart, it was perfect inside, we added some grease to the bearings while at it.
But obviously the ARb seals went n let some moisture in recently.
(21-05-2015, 05:29 AM)Paul_13 Wrote: I'll be in touch Stef some point in the near future. I need a 205 beam and a 306 beam
no problem paul just give me a message when your ready
05' Evo 9 IX GT
Team eaton.
If you're located near nottingham/grantham/Melton etc there's a place that rebuilds them for around £150 - don't quote me on that, that's what I got told by someone but their website is
https://www.imaxle.co.uk
Check this out
http://m.ebay.pl/itm/360747144597?nav=SEARCH
This is actually the one i got. Looks quality.
http://m.ebay.co.uk/itm/120976019232?_mwBanner=1
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
yeah thanks. thats the one been linked already.
I think I will see if I can win the whole peugeot set someone is selling. if not, get a shaftless beam already done
not sure why there what appears to be 2 pairs of driveshaft seals. I do have some good s/h shafts if that is what your looking for.
05' Evo 9 IX GT
Team eaton.
(22-05-2015, 10:16 PM)Stef205 Wrote: not sure why there what appears to be 2 pairs of driveshaft seals. I do have some good s/h shafts if that is what your looking for.
If I win all those I may contact you pal, I'll likely strip my beam and then ask you about measurements if thats not too cheeky?
If your talking about bearing depths measure it before you remove them.
05' Evo 9 IX GT
Team eaton.
(22-05-2015, 10:26 PM)Stef205 Wrote: If your talking about bearing depths measure it before you remove them.
I mean shaft measurements.
Tbh, I've never rebuilt a beam before, it's part of the reason I want to do it.... so in stupid derrrr mode...."bearing depths"??
There is so much I DIDN'T do with Pugs despite being trained in a pug specialist. We just sourced out jobs like that and did the fitting much to my disappointment.
Have you seen Gretsch-Drummers beam rebuild guide? It's pretty comprehensive. Smile
(23-05-2015, 07:53 AM)Toms306 Wrote: Have you seen Gretsch-Drummers beam rebuild guide?  It's pretty comprehensive. Smile
ah no, good point. thanks fella. will read up later
  Rear beam ...the good and the bad Mighty306 35 31,572 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,430 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,984 18-03-2019, 03:40 PM
Last Post: MOK
