Does 306 subframe fit into 205?
Hi guys im looking at a 205 project which has been started but not finished. The guy says he has fitted the 306 subframe, hubs and shafts to keep the 1.9 box for the xud9 conversion.
Is this even possible?
[Image: 20gh7o0.jpg]
No but fitting 306 hubs are although it will give positive camber
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Is this the bloke who once shown the errors of his very dangerous ways, never showed his face again?
http://306oc.co.uk/forum/showthread.php?tid=28092
(24-04-2015, 06:33 PM)Paul_13 Wrote: Is this the bloke who once shown the errors of his very dangerous ways, never showed his face again?
No paul this guys not a member on here at all. so basically best idea is to keep the 1.8 subframe and use the 1.8 box and shafts?
You don't need to change anything subframe wise to keep the xud9 box, having done the conversion myself!
You only need to swap the diff (for a 205 be item) or change the inner CV joint to a 306 item (which is considered a bodge, but I've done it myself and driven a fair while on it)
thanks for the info paul, unfortunately gonna have to give that one a miss then, shame. the hunt continues
If anyone has messed around with a subframe "conversion" I'd stay well clear
Second that. Its dangerous
If you find one iv got 2 gearboxes already converted if you need them Smile
Current cars
Subaru Impreza 2.0d - Daily
oh il keep you in mind dan. Posting a gearbox to northern ireland wouldnt be cheap im sure
  Snapped subframe ADV_93 4 3,451 21-09-2015, 02:24 PM
Last Post: bashbarnard
  Wishbone front bush bolt to subframe nut retainer? mattgreene 29 13,546 04-03-2014, 06:44 PM
Last Post: mattgreene
  Subframe help mikey b 12 6,249 03-01-2014, 08:51 PM
Last Post: mikey b
