Just went to take the subframe out of my ph1 dturbo and one of the subframe captive nuts are spinning in the floor does any one know if you can get to it or cut a bit out to weld it under the carpet any help would be good
Subframe help
02-01-2014, 08:42 AM
Never heard of that issue before. I always thought it was a threaded lug on the bodywork rather than a captive nut.
Got any pics? ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
02-01-2014, 08:58 AM
Ah no pics yet just started to take it out and the bolt is just spinning and down enough for the washer to be loose
02-01-2014, 10:07 AM
Which bolt?
The ones under the floor pan or the ones on the chassis legs? Yes has happened before...
02-01-2014, 01:21 PM
It's the bugger buy the gearbox tunnel passenger side will prob just chop the head of the bolt of and then sort when subframe out the way
02-01-2014, 01:34 PM
That would be my port of call. Are you referring to the one on the chassis leg? Or one by the exhaust tunnel?
02-01-2014, 01:54 PM
The ones on the chassis legs can be unbolted again...
IE its a retaining nut inside a cup which is bolted to the leg with two smaller bolts. Ive had these seize before...had to chop head off and get new 'cup' Wishes for more power...
02-01-2014, 03:53 PM
Slight hijack.
Can anyone tell me what size bolt 4 is. Part no 350925. Presume it means m12 x 1.75, just need to know the length.
Id guess 70mm
02-01-2014, 05:46 PM
Yeah the -69 probably means 69mm
02-01-2014, 06:31 PM
Got the subframe out now cut the bugger of will prob turn it into a stud with the thread down the bottom and weld the top or somet will have a look !!
| Snapped subframe | ADV_93 | 4 | 3,451 |
21-09-2015, 02:24 PM Last Post: bashbarnard |
| Does 306 subframe fit into 205? | rd070707 | 9 | 5,347 |
24-04-2015, 07:39 PM Last Post: rd070707 |
| Wishbone front bush bolt to subframe nut retainer? | mattgreene | 29 | 13,546 |
04-03-2014, 06:44 PM Last Post: mattgreene |
![[Image: mike_sig_zpsd438fb98.jpg]](http://i307.photobucket.com/albums/nn313/rallymark1/306oc%20Forum/mike_sig_zpsd438fb98.jpg)
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)
![[Image: 4BEE49A5-6F94-4DA4-9C0A-1BA1D15690C4_zpskh9xomk3.jpg]](http://i852.photobucket.com/albums/ab86/mikebaker345/4BEE49A5-6F94-4DA4-9C0A-1BA1D15690C4_zpskh9xomk3.jpg)
![[Image: FE37C37A-6CEA-44D2-BF73-7463D3C1B0C1_zpsolklupuv.jpg]](http://i852.photobucket.com/albums/ab86/mikebaker345/FE37C37A-6CEA-44D2-BF73-7463D3C1B0C1_zpsolklupuv.jpg)
