Correct type of thermostat?
Folks,
Changing my rad and was going to put a new stat in at the same time. Have had a look at the one in there, and it looks different to the one I've been supplied (by TMS based on my reg plate). The new one has a longer 'tube' and a wee spring loaded disc at the end, the original one does not. I think the new one isĀ  'bypass' type and the one in there I guess isn't. The car is a 97 Ph2 Dturbo, and the date code on the current stat is 04 97 so I guess it could be the original one.
Am I correct in thinking the one I have been given is wrong?
Cheers
Craig
If youre changing the stat seriously go genuine. Aftermarket ones are crap in my experience. For the sake of a few quid more. Gget a pic up and we can see if it looks right
  Is this the correct CG clutch???? Pompey306mark 7 4,093 24-02-2015, 08:17 AM
Last Post: Sambarker
  Is this the correct flywheel sensor? pugtk 1 2,335 17-02-2015, 11:49 PM
Last Post: vinny
  thermostat opening temps...lower temp' stats? Piggy 25 15,637 25-01-2015, 05:10 PM
Last Post: Piggy
