Boost take off pipe
Boost take off pipe
Where can I find myself a boost take off adaptor? In my head I know exactly what I want, but no idea what they're called or where to get one
http://www.ebay.co.uk/itm/Take-off-pipe-...1574794316?
How much?! Lol and didnt really want to take the elbow off to fit, was thinking of some sort of brass fitting, but no idea what to call it
I was thinking todayon the 206 about making one fit on the egr blank on the elbow?!
Drill and take your inlet elbow and fit 1 of these
http://www.ebay.co.uk/itm/321566446634?_...EBIDX%3AIT
I drilled and taped mine 5mm and fitted an air fitting takeoff
[attachment=19879]
This is what I've managed to find http://pages.ebay.com/link/?nav=item.vie...80&alt=web
Whilst we're all here, can anyone link me to an egr blank
The one I posted is good if you don't have a tapping set.
Meh, itll tap itself lol
I found an egr blank in my 1mm steel cutoffs. Then used a pen and some snips!
Thats what I was planning on doing, but if it's cheap enough ill just buy it and save faff
About £8 I think on ebay
But cost me nout, took 30seconds to make!
I have used these on my inlet.
http://www.ebay.co.uk/itm/371040919342?_...EBIDX%3AIT
They're about £3 each on ebay for the inlet side.
I bought this pair for complete EGR removal though - http://www.ebay.co.uk/itm/EGR-blanking-K...19d4650c72
Sorry...I was off by a penny!!! lol
But if he only wants one for the inlet side it's considerably cheaper than £8... We don't all have random lumps of metal hanging around either. Tongue
On another note though, I'm not sure how long 1mm plate will last. I've bought many EGR blanks over the years and not had any that thin. Confused
I have used the egr pipe clamp ontop of a 1mm plate with a gasket. Which has to be better than the lack of a gasket when I took the pipe off!!
Ah ok, fair enough, should be alright then.
No EGR gasket? Probably explains the whistle lol...
Its still there. Think its the metal elbow to plastic boost pipe connection...is there an O ring?!
Oh right. Confused
No O ring, just the silicone joiner with a jubilee each end if its the same as the 306, not sure if it is though!
Tough to see, have to have a dig at it tomorrow.
Looks like a bolt on flange
the egr pipe joint is a metal gasket use that as a templet and cut one out of steal as i have Wink
  Boost pipe pop mattbarker32 2 2,563 19-05-2017, 10:47 AM
Last Post: Midnightclub
  Lower boost pipe options. bashbarnard 12 6,734 12-10-2015, 07:14 PM
Last Post: ccr24
  Boost pipe popping off Jtrigga 6 3,687 02-09-2014, 09:05 PM
