Boost pipe popping off
So the silicone join to the plastic 406 pipe on the intercooler end keeps popping off. I've put 2 proper jubilees on there at once, tried a mikalor and sprayed it with hairspray but still it comes off any recommendations.
Bye Bye D-Turbo
(01-09-2014, 12:53 PM)Jtrigga Wrote: So the silicone join to the plastic 406 pipe on the intercooler end keeps popping off. I've put 2 proper jubilees on there at once, tried a mikalor and sprayed it with hairspray but still it comes off any recommendations.
Next steps to sack off the shitty plastic pipe and replace for hard pipe.
Has it still got the beaded end, or did you cut that off?
I cut off the beaded end to make it fit I've put on 2 jubilees now and cable tied the pipe to stop it moving I'm hoping that has sorted it out.
Bye Bye D-Turbo
That pipe needs sacking off asap. Custom sillicone with metal pipe routed under the engine to the intercooler work a treat.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
You could heat the pipe gently and form a new bead or more easily a raised end into it.
Yeah that bead is necessary, you might be alright if you hash the hell out of the mating surface.
  Boost pipe pop mattbarker32 2 2,790 19-05-2017, 10:47 AM
Last Post: Midnightclub
  Lower boost pipe options. bashbarnard 12 7,442 12-10-2015, 07:14 PM
Last Post: ccr24
  Boost take off pipe Connor 21 8,560 03-11-2014, 09:16 AM
Last Post: cully
