2.0 hdi 90 blueish smoke under acceleration
hi I was driving normally yesterday when all of a sudden I noticed some blueish smoke from the exhaust which almost goes if driving gently, however if I take the revs up its blowing out a fairbit of blueish smoke.
iv had the rac out and engine runs sweet as a nut with no over heating,and no smoke from cold start, and no smoke idling.
coolant level is fine and oil level full
any ideas??
Likely to be turbo blowing oil through the seals. Whip the boost pipe off and see how much oil is there!
How many miles has it done?
its done 145000 miles mate
Could well be turbo.
Is fuel consumsion the same?
yeah haven't noticed any changes in fuel consumsion
Whip the boost hose off and see how much oil is in there. If can get it off, air inlet pipe off too to see if theres much oil there.
I wouldnt reccomend driving it till you find the problem. Could burn the oil and start runnig away
  Noise on acceleration after 3500rpm. Video daveylennon93 21 10,033 07-11-2014, 06:48 PM
Last Post: Ruan
  Acceleration Wolverine1091 26 13,339 06-02-2014, 06:57 PM
Last Post: Mr Whippy
  Rattle under acceleration upto 3k Jukie88 37 20,644 28-06-2012, 04:32 AM
Last Post: gareth7
