internal fuel line diameter
I need some more fuel line to feed my Bosch pump. What internal diameter line should I get? just swapped my Lucas for a Bosch on my 205 xud and need longer line.
Many thanks
Chris
Pretty sure its 8mm bore.
im pretty sure the standard size is 8mm, but if your thinking of running veg or chasing big power and high rpm you could up size to 10mm. you would have to change the banjo, fuel primer etc to 10mm too
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
I run 3/8ths on mine, works well enough
/Toseland
Standard feed is 8mm and the return is 6mm
If you are gonna re-pipe the whole car the take off on the tank is just under 10mm so its possible to run 10mm or 3/8ths the whole length of the car which will give you alot more fuel flow and does make a difference even on a 9mm pump.
Star Xud engine code/ internal parts needed mrmoates 4 4,950 29-09-2017, 09:08 AM
Last Post: welshpug
  XUD fuel line length kee616 31 25,715 30-12-2014, 09:10 AM
Last Post: bashbarnard
  auxiliary belt length with different power steering pulley diameter juz22 1 2,824 18-10-2014, 05:02 PM
Last Post: Niall
