14-08-2014, 06:13 PM
Right, if I weld the flap shut on a t2 for the wastegate arm and left the wastegate arm off the turbo and plumbed in a mbc could I control the boost with the mbc or am I missing something
Turbo talk
14-08-2014, 07:15 PM
Mbc by itself will control boost. If you weld anything you take away ability to adjust it.
15-08-2014, 01:25 AM
Yess Danny you are missing something. When the MBC opens at a set pressure it opens the boost can which opens the wastegate, If this is welded closed then it wont open rendering the MBC useless...
15-08-2014, 07:39 AM
Had a think about it this morning when I'd sobered up and realised that wouldn't work
Welded shut and control with fuel seems to be the way I'm going then
15-08-2014, 02:54 PM
If the wastegate is just disconnected, what will a T2 push up to ?
On a 9mm with max fuel screw adjust just lower than 2K revving and LDA rotate.
16-08-2014, 05:01 PM
Did you get any pics of turbo?
3 x Peugeot owner.
1996 106. 1996 306 D Turbo S. 1994 Mercedes Benz 320E. 1997 306 GLX. Subscribe! - https://www.youtube.com/user/TheADKJD/videos |
| Talk exhaust.... | blinkyeatu | 20 | 11,517 |
24-08-2015, 08:42 PM Last Post: 306pc |
| Turbo talk. | bashbarnard | 65 | 39,121 |
30-10-2014, 09:33 AM Last Post: bashbarnard |
| Turbo talk | David | 43 | 26,868 |
11-11-2012, 10:26 AM Last Post: Ruan |
