Couple of bosch questions...
When switching from a lucas to a bosch is the plug for the stop solenoid the same and will it be and issue that my dt has an immobiliser?
Also does anyone know the thread pitch of the studs for the pump? Gonna get a couple of nuts to extract them instead of using the ones for the pump itself
Cheers!
No smoke, No poke!
Its just a 12v ignition to the stop solenoid on the bosch, this can be spliced from one of the cables that originally went to the lucas, think its red or yellow? The studs are M8.
Brilliant, cheers!
No smoke, No poke!
99% sure its the red wire from the lucas plug that your looking for Wink
Cheers! I'll check it with a multimeter first, does the immobiliser pose a problem at all?
Also do you know where i can get an injector seal kit?
No smoke, No poke!
Injector seal kit pug or motor factor might do them, no problem with immobilliser once you run ignition to solenoid valve.
That will do nicely cheers for the help Smile
No smoke, No poke!
http://m.ebay.co.uk/itm/270732384297#ht_500wt_1156
Here is the address for ev bosch pump kit seal :-)
I swaped my lucus for a bosch nt long a go just make sure u get every thing with it like bracket injector lines and so on lol
Says the listing has ended and item has been removed pal
No smoke, No poke!
Think this is what he wanted paddy.
XUD Injector Fire Seals and Copper Washers
Correct me if i'm wrong though.
(05-08-2014, 11:42 AM)mr_fish Wrote: Think this is what he wanted paddy.
That is precisely what I need! Thank you sir!!
No smoke, No poke!
Lol ohhhh right :-)
  Bosch pump questions bashbarnard 9 5,662 03-05-2014, 12:18 PM
Last Post: pugmanxud
  More Bosch pump questions Martin306 9 7,562 17-12-2013, 01:36 PM
Last Post: Dave
  Couple of questions Fozzy 4 3,004 13-12-2012, 09:24 PM
Last Post: Fozzy
