More Bosch pump questions
Is there a way of knowing what size the plunger is from a part number? My googling skills have failed me Sad I think I have an 8mm plunger.
Say VE R 0 460 484 099/100 or 0 460 484 148
Also, if you've removed your LDA screw (Sam mentioned something about that ), tell me and let me know what powahz you're getting and spec.
Thanks in advance.
correct 8mm plunger
0 460 4*8*4
That 8 is the plunger size in mm.
LDA is the positive manifold pressure enrichment system... Ie. More boost, so can burn more fuel... There's no LDA screw to remove and won't improve power.
(16-12-2013, 11:30 PM)padge Wrote: correct 8mm plunger
Big Grin
(16-12-2013, 11:37 PM)Ruan Wrote: 0 460 4*8*4
Thanks, so the 6th digit is the plunger size then! Smile
I think he said some people take the top hat off and pull the pin out? I don't have a top hat on my pump, cos it's a NAD pump. but was just curious! Big Grin
106nads all had 8mm heads Smile
They wont have an LDA as ruan said coz it aint a turbo Smile
(17-12-2013, 07:17 AM)Piggy Wrote: 106nads all had 8mm heads Smile
Thanks Tongue but that's not what I was asking.
I was asking if there is anyone using a VE with a disabled LDA on a Dt to step forward and tell me your spec Idea
i have heard of people doing it but it'd be very smoky low down, would require some deft left foot control, can't think why you'd really want to though tbh . .Smile
think chris_90 is running a 9mm 306 turbo bosch pump on his 106 diesel
(17-12-2013, 12:47 PM)Teddy Wrote: think chris_90 is running a 9mm 306 turbo bosch pump on his 106 diesel
I would do that, but I have an ECU controlled NAD Bosch pump. I'd like to keep that Smile The knock without it is horrendous.
Im sure when I changed from 9mm to 11mm it gave me slightly more torque lower down, could be in my mind though, but then it could be something to do with injection duration/timing.
  Slack in bosch pump? dt_ 14 10,150 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,056 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 2,804 12-03-2019, 06:47 PM
Last Post: Forby
