02-04-2012, 11:08 AM
Rear brake protector shield for discs has corroded away on one side. How does it come of with what nuts or hex keys etc?
02-04-2012, 11:13 AM
IIRC they are held on with 3 allen keys or torx bolts (I cant remember which though)
02-04-2012, 12:02 PM
what matt said. did mine a while back, but rounded a couple off, so left them. use a SHITLOAD of penetrating fluid.
02-04-2012, 12:05 PM
samass Wrote:use a SHITLOAD of penetrating fluid. Giggity . Captain Standard
02-04-2012, 12:09 PM
Toby Wrote:samass Wrote:use a SHITLOAD of penetrating fluid. lolz Member of the 99% warning or you're nothing club
02-04-2012, 08:19 PM
4WayDiablo Wrote:take the wheel off and have a look? I got both wheels of at the moment doing the back brakes.
04-04-2012, 10:57 AM
The nuts are all warn out so Ive just cut the disc shield best I can removing it of. I might spot weld anther on in place if thats ok to do?
06-04-2012, 09:37 PM
I got the 3 bolts out in the end I used mole grips to get them out. Then went to the scrap yard and got anther brake shield gaurd. So the job done now which Im glad and its now sorted out.
The ones in the scrap yard come of easy to it saved alot of work on those. Then made it easy to fit them back on after. |
Do I buy? rear brake pipe corroded, covered in grease or other material pipes | Charlie0 | 3 | 6,788 |
18-04-2019, 10:14 AM Last Post: Mighty306 |
Uneven brake drag on rear wheels | balkan_bozo | 2 | 2,053 |
21-10-2018, 11:10 AM Last Post: balkan_bozo |
Rear brake compensator leaking | Ben | 4 | 2,937 |
24-04-2018, 07:11 PM Last Post: Ben |
