Uneven brake drag on rear wheels
Just completely overhauled rear brakes, new shoes, cylinders, all brakes bled.
But then the drag on the driver's side is substantially more than the passenger side. The handbrake adjuster thingy in the hubs are set to minimum. Brakes were pumped, no change, check this out.
Passenger side: https://youtu.be/kn8oDAKlC5g
Driver's side: https://youtu.be/31NCl7HXElg
I have no idea how to deal with this, assistance most appreciated!
That's normal. Just drive it.
You're fitting new stuff to old drums, the drums will never be perfectly worn on each side by the same amount.
I was so hoping someone would say that :-) thankyou :-)
  Uneven rear tyre wear rydon 12 8,502 13-06-2019, 04:18 PM
Last Post: Nexus
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,113 18-04-2019, 10:14 AM
Last Post: Mighty306
  Rear brake compensator leaking Ben 4 5,931 24-04-2018, 07:11 PM
Last Post: Ben
