HDi lower intercooler pipe
My 406 one lasted a matter of weeks and the 2.2 HDi one although better has now somehow split in two and is leaking something terrible.
So I set about making a nice stainless one but discovered a simple 90 bend is the perfect shape to tuck nicely in the gap between engine and gearbox. I welded on a reducer to the end to fit my silicone but this is not needed, so if you could get old of some old 90 stainless bends you could have yourself a cheap much improved lower pipe and lose that 38mm restriction on the OEM pipes
Its actually a better fit than the 2.2 one which is bent about 80 degrees or so, could be worth a rummage in the local metal recyclers Smile
from this :
[Image: a8ygurah_zpsdb93bade.jpg]
to this :
[Image: DSC_0071_zpsqh90ggwc.jpg]
So you going to start making these for others then?! Hehe
[Image: Sig500x130.png]
f*ck the 90 degree bend off and see if you can get a 45 degree in there
You could easily do that or even get it so a straight joiner fits but this is a more simple design for those looking for an alternative Smile cheap to make/have made for you
How long did you make the straight pipes matr
That 90* pipe looks nice but IMO the 2.2 one looks like it would flow better.
  Lower air box pipe diameter? JTaylor2005 2 2,380 26-01-2016, 09:22 PM
Last Post: DeeTurbo
  Lower boost pipe options. bashbarnard 12 7,261 12-10-2015, 07:14 PM
Last Post: ccr24
  2.2 intercooler pipe? mattyh24hdi 41 20,798 26-06-2015, 09:09 PM
Last Post: tigerstyle
